Fairbanks Morse Diesel - 2cyl
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Topic: Fairbanks Morse Diesel - 2cyl
    Posted: 16 Apr 2012 at 5:22pm
Was looking up some ships and noticed the 2cycle diesel used in some ships and subs.
Now a little different type as one cylinder and 2 pistons in it along with two cranks, geared to each other.
  This picture illustrate the difference in size between the 8 cyl Fairbanks and the engine block of a 6 cylinder Caterpillar 3306, a similar size engine as found on large highway tractor trucks.
Lee Bradley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lee Bradley Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 6:57pm
The Jumo two cycle diesel aircraft engine from 1930s (Germany). Jumo would later build
some of the first jet engines.
File:Jumo205 cutview.JPG
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 8:53pm
Same design also used in the FM RR Locomotives
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 10:31pm
used them on the Zeppelins also
I am still confident of this;
Wait for the Lord;
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2012 at 4:22am
Coke,
Check out the Napier Deltic diesel.  e.g.
More including sound tracks if you use the googler
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2012 at 8:34am
little town by our farm of Owensville MO had a power plant of their own and are currently dismantling it, it had three large diesels two of which were FM engines, they put the gas axe to them as no one would buy them complete and worth more as scrap steel.
