Fair deal here?
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Topic: Fair deal here?
    Posted: 11 Apr 2018 at 8:28pm
 I found this B10 and called about it.  Man lost interest in the restoration.  Missing the grill and the motor is bored 10 over.  Says it ran at one time.  Looks like a good priced project to me.  What should I look for?  Is this deck correct?  What is the motor supposed to be?
https://ocala.craigslist.org/grd/d/vintage-allis-chalmers-garden/6555388279.html
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2018 at 10:56pm
I think it is a fair deal.
And I'd grab that starter generator while I was at it if it's not needing rebuilt or haggle if it does.
It's looks like the original engine is in there.
Also, it appears to be the original deck.
Don't know per se what to look for on these other than the normal worn things.
You might happen upon a grill down the road, or, make your own to insert.
Just an idea of a direction to think of.
How blessed we are by HIS GRACE!
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2018 at 5:30am
2 things to check.  The gas tank for pinholes, as good tanks are near impossible to find and run dang near $100 if you do.  Check the bevel gear box (BGB) for play.  They are not too hard or expensive to rebuild, but it can be a bargaining chip.  Check the deck spindles for bad bearings too.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2018 at 5:49pm
Thanks all.  Looks like a fun project.  If it lasts until Saturday I'm running to go get it.
1940 B "Lucy"
1972 314H
Herb(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Herb(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2018 at 7:14pm
Condition of gas tank; Have experienced good results with gas tank sealer Kreem. Herb(GA)
