Failure WARNING
skyboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skyboy Quote  Post ReplyReply Direct Link To This Post Topic: Failure WARNING
    Posted: 28 Aug 2018 at 8:43am
As I mentioned, had a very frightening could of been catastrophic event.
 Raising EMPTY forks near top , then the forks "fell to about a 45 degree angle" hanging off the carriage,  very loud and scary!  I wondered how this type of failure could possibly happen?
 My old mast bearings failed and  the carriage moved forward due to the weight of the forks, allowing the bearing stubs to get past the stop blocks welded to the top of the mast.
 That began the search for the proper mast bearings,  Komatso wanted nearly $1,200 for 4 bearings.  Much time was spent looking as I've "crossed over" bearings like everone for years.   You won't do that with "mast bearings" probably due to just the kind of failure I had, probably got a million dollar umbrella insurance policy on replacements!!  I found (4)  Enduro 5108BZZ1 for $327.
  In short I don't think the engineers could have ever envisioned the bearings being used to "both" failed at the same time.
 I'd urge all who have an older lift to inspect at minimum the 2 top bearings on their carriage.
jerbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2018 at 9:12am
Thank GOD you or anyone else was hurt. Scary stuff for sure. Equipment failures can have serious effects for sure.
HD16DC, Bobcat 863 Turbo, Oliver 1855, John Deere 855,
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2018 at 6:40pm
bearing MR 5306-2RS | Price and Sizes | SKF,FAG,INA,NTN ...
pearlfwb.org/5011-bearing-MR-5306-2RS.html
Suspension15 New PL0 2015 Full .xlsx - Enduro Bearings pdf ... 5108-BZZ-1. ... Enduro, 6805 2RS, Bearing, Ball, Contact to Order, Stock in Oakland, CA.
