factory duals for 180
joshjohndeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joshjohndeere Quote  Post ReplyReply Direct Link To This Post Topic: factory duals for 180
    Posted: 22 May 2010 at 11:22pm
i have a very old original production parts book from my grand father for d-17 tractor in the parts book it shows a hub assembly that bolts up to the final drive with the wheel on the tractor. the hub assy is to mount another poweradjust rim/tire assy to for factory adjustable duals. has anyone ever seen this and did they make on to fit a 180 ?
Wes (VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2010 at 11:31pm
have ya got a picture you can scan to put on here?  got my curiosity up...
Post Options Post Options   Thanks (0) Thanks(0)   Quote joshjohndeere Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2010 at 11:59pm
yes i will try to scan it and get it on here it looks like u bolt on the inner dual with 2 bolts to the final drive, then put the dual hub up and put the remainder of the bolts in. then bolt the outer poweradjust rim assy. to that.
