F50-24 fork lift help needed
Jewell1386 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jewell1386 Quote  Post ReplyReply Direct Link To This Post Topic: F50-24 fork lift help needed
    Posted: 09 Jan 2020 at 9:26am
I have a f50-24 forklift I am trying to get a head gasket kit for. Most research I have done pointed to the Buda engine. Order the gasket kit for it from Steiner tractor parts and upon arrival it is not the correct kit. I have a few numbers on the block but am not finding much by searching the numbers. I believe on the side is stamped 45158288 the 7th digit is a ? Any help would be great
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2020 at 9:44am
hmm 4 cyl or 6 cyl ?
My FPD50-24 has a BUDA 4BD153( ?) diesel engine in it, same block and most parts as in a Cockshutt '30' gas tractor.
There's cockshut manuals online somewhere.....
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jewell1386 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2020 at 9:47am
4cyl I can’t get a pic to load it is to large. All gaskets appear to be correct except exhaust side. I can email pic if you wish
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2020 at 12:27pm
Been a while but remember having to go to an Allis dealer because there was 2 different types of manifold gaskets and the kit came with the more common.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jewell1386 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2020 at 3:39pm
You are correct there was a tractor version then an industrial version produced by buda. It is a buda production engine with the industrial head. Manifold gaskets and valve cover gaskets are different. I am trying to find out the industrial kit number then i can find that part of at all possible
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2020 at 8:39pm
'fun' fact. The BD153 engine can have either 3 or 4 rings per piston.the 'fun' part is you have to tear it down to find out...so you can't preorder the parts....
'fun'.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2020 at 8:03pm
Is this a gas or diesel?
This page was generated in 0.734 seconds.
