F40 Fork Lift with M5 mast
oldyellowlift View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldyellowlift Quote  Post ReplyReply Direct Link To This Post Topic: F40 Fork Lift with M5 mast
    Posted: 22 Aug 2022 at 7:48am
Hi All -
My business owns an Allis-Chalmers F40 fork lift that is equipped with an M5 mast.
The lift was used occasionally up until about 4 years ago.  It ran as recently as 2 years ago and I have no reason to believe that it won't fire up and run now.  (The LP tank is out of date and does need to be re-filled.  There is currently no battery for the lift.)
The time has come for it to find a new home.  Any reasonable offer will be considered.  The lift is on the east side of Richmond, Virginia near the airport (zip code 23231).  It is being stored in a warehouse that has dock bays and a drive-out door.
A couple of pictures of the lift and the data plates are attached, and I can take detailed pictures for anyone serious about buying the lift.  (The lift's data plate is particularly hard to read, so if you need me to confirm any of the information on the lift, just let me know.)
Thank you!
Edited by oldyellowlift - 22 Aug 2022 at 7:53am
Rick Sherwood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Sherwood Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2022 at 10:53pm
Hi how much are you looking to get for it? Would you consider parting it out?
This page was generated in 0.258 seconds.
