F3 won't start
Ben (MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Topic: F3 won't start
    Posted: 22 Jun 2024 at 11:58am
Hello,
I started the combine today so I could move stuff around in the shed. It popped right off like always when it's above 70 degrees out. It ran for 5 seconds and then quit. It will now only fire on either for a second but that's it. I replaced the fuel filter making sure it was full of fuel. I cleaned the sediment bowl which was pretty clean anyway. I noticed that I have a beautiful double stream coming from the tank to the bowl, as long as the bowl is removed from the base. It takes several minutes to fill the bowl when on the base. I tried with the fuel cap off, same deal. There's a half tank of fuel. What is going on here, please?
Part time farming with a 1980 7060 and 1984 F3 hydro.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2024 at 12:01pm
Leave the bail nut loose until the bowl is full and then tighten it up. That is very normal what you are describing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2024 at 12:19pm
Perfect, thank you. Back to the drawing board on the no start. I'm just going through the troubleshooting guide in repair manual step by step. Thanks again!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2024 at 1:33pm
My F2 loses it's prime over winter. It will fire right up and then die. Go pump the primer and good to go. Just like my 220.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2024 at 2:14pm
Thank you Steve, I will give it a try.
analogguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote analogguy Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2024 at 3:10pm
I have seen the fitting on the top of the injection pump plug with pieces of the governor shock ring. Remove fitting and see if it will start.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2024 at 3:18pm
Thanks Steve and Analoguy. Priming did the trick, luckily. I didn't want to mess with the pump. Appreciate both of your input. This serves as my reminder to start it monthly in the off season.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2024 at 1:49pm
Or just pump the primer before you begin and it will be fine
