F2 motor into a d19.
Valleyfarmanddiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Valleyfarmanddiesel Quote  Post ReplyReply Direct Link To This Post Topic: F2 motor into a d19.
    Posted: 12 Aug 2022 at 2:29pm
Has anyone on here replaced a d19 gas motor with a gleaner f2 motor? Having trouble with the starter. Not sure if I need to swap ringgears, starters or if it's even possible. Had to use the gas flywheel that is set for a 9 tooth small drive and the f2 is set for a 10 tooth 40mm drive. Let's just say the ten engages but locks her up tight. I am finding this was a bad idea but am stuck finishing it.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2022 at 9:27pm
I would bet (Steve In NJ) on here can fix you up with the right drive.                  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Valleyfarmanddiesel Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2022 at 9:09pm
Going to pull the motor again and see if I can swap the ring gears. Hope I works. Went to a couple starter shops and no luck. Tried to look up Steve in NJ but no luck. Thanks mack
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2022 at 9:17pm
Steve might not be able to FIX... but he sure could fill you in on possibilities...
Edited by steve(ill) - 15 Aug 2022 at 9:21pm
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2022 at 9:19pm
B&b custom circuits on the web
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
