F2 motor into a d19. |
Valleyfarmanddiesel
Topic: F2 motor into a d19.Posted: 12 Aug 2022 at 2:29pm |
Has anyone on here replaced a d19 gas motor with a gleaner f2 motor? Having trouble with the starter. Not sure if I need to swap ringgears, starters or if it's even possible. Had to use the gas flywheel that is set for a 9 tooth small drive and the f2 is set for a 10 tooth 40mm drive. Let's just say the ten engages but locks her up tight. I am finding this was a bad idea but am stuck finishing it.
MACK
Posted: 12 Aug 2022 at 9:27pm |
I would bet (Steve In NJ) on here can fix you up with the right drive. MACK
Valleyfarmanddiesel
Posted: 15 Aug 2022 at 9:09pm |
Going to pull the motor again and see if I can swap the ring gears. Hope I works. Went to a couple starter shops and no luck. Tried to look up Steve in NJ but no luck. Thanks mack
Joined: 11 Sep 2009 Location: illinois Points: 90800 |
Posted: 15 Aug 2022 at 9:17pm |
Steve might not be able to FIX... but he sure could fill you in on possibilities...
![]() Edited by steve(ill) - 15 Aug 2022 at 9:21pm |
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 722 |
Posted: 15 Aug 2022 at 9:19pm |
B&b custom circuits on the web
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
