F2 Engine
Lynn TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn TN Quote  Post ReplyReply Direct Link To This Post Topic: F2 Engine
    Posted: 03 Dec 2009 at 6:30am
We recently bought a F2 from a neighbor that had sat in a shed for several years. It cranked right up, really just bought it for parts and for the good black cornhead, will the motor in it fit right in a 6080? The motor is tight only shows 1000 hrs, but machine is in worse condition than our current F2, would like ot buy a 6080 if the motors interchange. Thanks.
niele View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote niele Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 10:33am
It will take some changing to get it to fit the front mounting plate and timing cover because the hy. pump mounts to the front mounting  plate the back plate I think might need to be changed injection pump you would have to run a wire from the key switch because the combine has an electric shut off  Niel
