External loader
dpage02 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpage02 Quote  Post ReplyReply Direct Link To This Post Topic: External loader
    Posted: 18 Feb 2010 at 10:55am
I have an external farmhand loader (external hyd tank and pto pump) mounted on the tractor. The hyd has been left exposed to the elements and lines have been contaminated. I need to flush things out and clean the system. What is the easiest way to do that? I want to also mount an external hyd filter. Should I put it in the return line before the hyd tank or between the tank and the pump?
kip in cny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kip in cny Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2010 at 11:19am
I would replace the hoses.  put the filter on the return side and put new cheap oil in it. drian and refill and buy a few filter
160 CA 920diesel 5020 HD-3
