Expensive toys
Steve allis dozer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve allis dozer Quote  Post ReplyReply Direct Link To This Post Topic: Expensive toys
    Posted: 29 Mar 2012 at 5:52am
Have $12000 into the engine rebuild   for  my HD11EP  project  brought this tractor in 1995 has has been a long time but it is finaly coming together!!
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve allis dozer Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2012 at 6:01am
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve allis dozer Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2012 at 6:03am
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2012 at 6:50am
That's going to be purdy when done, well worth your efforts and purse book drain, nice to see folks going the "extra" to preserve the old AC Machines. They just don't build em' like they use to.
Mactractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2012 at 4:39am
That the early EP with power brakes, Twin Disc converter, and tall forward gearing Steve?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2012 at 6:11am
Only 12,000? ....cheaper than getting married !
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve allis dozer Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2012 at 7:37am
Yes has power brakes , twin disc convertor, am not sure on gearing,   the radiator  top grill is made of welded mesh insted of pressed holes  like the late ones
Regards Steve
doctorcorey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2012 at 9:11am
  I hear that: a lot cheaper than getting a divorce.Cry
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2012 at 12:49pm
Steve I have a great appreciation for guys like you that take on these big projects, Besides that crawler's are in a special category cuz they are hard to move once your done therefore not easy to show. Thanks for posting the pics    Mark
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2012 at 1:47pm
I can appreciate that. Keep up the good work, you'll have a nice machine when you are done.Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2012 at 2:42am
Your rebuild job is very impresive Steve. The grill you mentioned would be to allow better cooling. My EP (same model) gave cooling problems until I fitted a grill that allowed much more air flow. I made one with 3/8 rock sreening mesh. Unrestricted air flow with good shielding against tree limbs and scrub. Keep up the good work.    Mac
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2012 at 4:24am
Steve and Mac
The fashion around here is to make a grille with flat plate at about 45 degrees up and wide enough that they shield one another from the front.  Some of our sticks can be real trouble if you push into the head of a tree with mesh in front.  And this design doesn't seem to restrict the cooling.
If I work out how to post a photo I have one of these on our FA 10 but the description should work.
Ian
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2012 at 4:41am
Steve,
Been down a similar engine track with an AC "Forty Five".
Came with a dead engine (rod bearing).  Tripped over a short motor out of a liquidation sale - with "overhauled injection pump".
Plus local help and we had two good heads and 15 injectors to test.  Got 8 useable.
Then found a massive diesel leak into sump.  Now know more about Am Bosch rotary pumps.  The "overhaul" left ihe bottom O-ring out of the head sealing, squashed the clip holding the sub-tappet to the head for install and was one tooth out on timing.
Then we had return to idle problems, which diesel apprentice son tracked down (over about a day) to a burr on the control shaft that runs the spill valve in the head.
We've seen a lot of the insides of one of these pumps!  Including the strategic extra wire on the govenor linkage on our test model from the original engine.
It started OK timed one tooth out - but the plunger was hydraulic locking until the port opened.  Now needs a short squirt if ether, but runs fine after that.  I think I can live with this - it is a ranch grader - but comments would be welcome
Ian
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2012 at 11:47pm
Great effort Steve. One hell of alot of work; but if you,ve got the patience; knowhow; money; and a great workshop; you can fully rebuild most dozers; and at least then you know what you,ve got and can hopefully expect 6000+ hours of trouble free dozing. Tongue
To my way of thinking is a better option; and cheaper; than going new. Down here at the bottom of the world a new D6 is about 600,000 pacific pesos, and i can think of better things to spend that amount of coin on Cry Not that i have anywhere near that anyway; but will have to do some major rebuilding to my D6D this winter.
Hows your other crawlers going ? Don,t be shy put some pics up of them too Big smile
Cheers Merv
tits tyres and tracks
they all cost you money
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2012 at 12:51am
wow...that's a clean work area!!! whew!
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve allis dozer Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2012 at 5:03am
  G'day merv here's some pics for you  Series B  Allis with  a stick rake  that I made
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve allis dozer Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2012 at 5:04am
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve allis dozer Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2012 at 5:25am
[TUBE]e1yn9oASg-s&feature=player_detailpage[/TUBE]
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2012 at 5:15pm
Very impressive mate; thank you for posting.
cheers Merv
Faron View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Faron Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2012 at 5:51am
I just thought i would check up on your rebuild and see how it is going. My 16 is in the corner of the shed taking up space as i can not bring my self to put it to work so I bought DX175 and use it instead.
