|  | This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | |||||
| Exhaust Manifold Studs |
| Post Reply   |
| jerbob   Orange Level     Joined: 07 Aug 2017 Location: Michigan Points: 961 |  Post Options  Thanks(0)  Quote  Reply  Topic: Exhaust Manifold Studs Posted: 12 Apr 2018 at 2:34pm |
   Hello Everyone.  I had taken off both my muffler on my HD16 to repair and while I was at it, took off the exhaust manifold as well to clean and paid. Muffler turned out great. While taking off the exhaust manifold, two studs snapped off however I was able to get them both out without damage to the heads. in replacing the studs are they anything special? They are 1/2" and threaded on both ends of course. Do you need to place any Loctite on the ends going into the block or is that a no no? BTW I found a small whole worn through on on of the ports but cleaned it up and JB welded it just fine. I found two adjustable bands around this one port and was hoping it was not holding the manifold together. Someone had used the two bands to hold a piece of high temp material over the whole to plug it up. Overall manifold is pretty solid to my relief. | |
| LeonR2013   Orange Level     Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |  Post Options  Thanks(0)  Quote  Reply  Posted: 12 Apr 2018 at 9:33pm |
   If it's been working I don't believe I'd try to fix It. You might take what you have and try to improve on it a bit. Sometimes these little fixes hold up quite well.
| jerbob   Orange Level     Joined: 07 Aug 2017 Location: Michigan Points: 961 |  Post Options  Thanks(0)  Quote  Reply  Posted: 13 Apr 2018 at 6:27am |
   Agreed. Just cleaning, all new gaskets, and painting. Treating it gently as these manifolds are impossible to replace.  My son works with s prototype engineering company and are going to scan my manifold and see about milling a new one. Just looking into it but if they do it, might be something to offer this great group. | |
| Post Reply   | |
| Tweet |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
