Exhaust manifold on an E combine?
KurtDE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KurtDE Quote  Post ReplyReply Direct Link To This Post Topic: Exhaust manifold on an E combine?
    Posted: 02 Mar 2010 at 7:06pm
Is the exhaust manifold on the E the same as the 170 gas manifold? I am looking at the E motor to replace my 170 and the 170 needs an exhaust manifold.        Kurt
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2010 at 9:00pm
It'll work....good luck getting that 90 degree elbow unthreaded from it and installing the 170 pipe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KurtDE Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 4:42am
Thanks for the info Dr Allis.
wheelbilly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheelbilly Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 10:23am
I used a hack saw to cut the elbow off flush with the manifold and then used a dremel tool with cutting disk to split the part of the elbow still inside.  Used a  chisel  to force in a bit and then screwed it out.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 10:44am
I did the same a Wheelbilly.
