|  | This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | |||||
| excessive white smoke |
| Post Reply   |
| JRM914   Bronze Level     Joined: 06 Dec 2012 Location: Mendon Michigan Points: 5 |  Post Options  Thanks(0)  Quote  Reply  Topic: excessive white smoke Posted: 06 Dec 2012 at 1:06pm |
hello I have a FL40  Allis fork lift with a Buda G-153 engine and it has a  carb it started smoking real bad it would fill a 2500 sq ft building in seconds so you could'nt see 20 ft away the engine runs ok no engine miss dead cylinder  It had a coolant smell to me so I pulled the head expecting to see a blown head gasket it wasnt blown sent the head to machine shop had it pressure checked it is ok.  What can be the problem? Only other thing to note is it is a bit overfull on oil not with antifreeze but gas smell  this thing is not used very often and short running times that is what I contribute the over fill and smell in oil
| D-17_Dave   Orange Level   Joined: 11 Sep 2009 Location: Mocksville NC Points: 990 |  Post Options  Thanks(0)  Quote  Reply  Posted: 06 Dec 2012 at 1:35pm |
   Do you have an external fuel pump on the side of the engine? Sounds like the diaphragm went out and thinned the oil down until it started passing oil past the rings.
     Yea, I can fix that.....
| JRM914   Bronze Level     Joined: 06 Dec 2012 Location: Mendon Michigan Points: 5 |  Post Options  Thanks(0)  Quote  Reply  Posted: 06 Dec 2012 at 1:52pm |
   thank you we were thinking that also since there was no head problem the smoke i thought had a antifreeze smell maybe just in my head.  thanks again
| Post Reply   | |
| Tweet |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
