excavator
farmer0_1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer0_1 Quote  Post ReplyReply Direct Link To This Post Topic: excavator
    Posted: 22 Sep 2011 at 2:53pm
  looking for some input on a cat 312 trackhoe.    it doesn't have a thumb under 4000 hours   i notice that the prices on these series is low compared to other breeds.  are they junk?   http://www.machinerytrader.com/listingsdetail/detail.aspx?OHID=7717323&      hope this is not improper to post  this way.  i would like to buy and i am looking for issues.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2011 at 3:31pm
The Caterpillar 312 hydraulic excavator was introduced in 1992 in Japan and France.
The 312 has a Cat 3054 turbocharged, diesel engine producing 84 flywheel horsepower (FWHP). It comes standard with a variable flow hydraulic system with a power and work mode selector, pilot activated control, horsepower summation control, high level of operator comfort, large cross-section design for the boom and stick, modified X-shaped carbody, increased stick and bucket force, and increased pressure in the travel circuit.
The 312 was manufactured in Japan, with a 6KG or 7DK serial number prefix; and in France, with a 6BL prefix.
Production ended in Japan in 1996; it was replaced by the Caterpillar 312B.
Based on data from the sales database of Ritchie Bros. Auctioneers, it is estimated that more than 11,700 Caterpillar 312 hydraulic excavators have been produced.
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2011 at 4:46pm
Call  around  and  check  on parts  before  buying ,  Cat  may  be  only  source for  parts,  also make  sure it  isn`t  a grey  market  machine repainted & decaled.  Tony
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2011 at 5:06pm
It may be worth your while to run oil samples on the engine and hydraulic system. An excavator with metal in the hydraulic system can be a real bad situation. A friend is a used equipment manager for a very large John Deere construction store group. They had a Hitachi with pump shavings in the system. Whatever they tried to clean the system did not work. I think it became a parts machine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2011 at 8:03pm
friend had JD hoe and estimate to rebuild hyd after metal was found in oil samples was $20,000. machine was not worth that so he has it for parts and bought another one similar.
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer0_1 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2011 at 10:44pm
great idea on the oil sampling on the engine and hydrualics.   my next door neighbor had his 1266 int pump chips thru his tractor and sold it for the engine.  keep them coming.
