excavator |
farmer0_1
Joined: 06 Dec 2009 Location: cornelius or Points: 592 |
Topic: excavatorPosted: 22 Sep 2011 at 2:53pm |
looking for some input on a cat 312 trackhoe. it doesn't have a thumb under 4000 hours i notice that the prices on these series is low compared to other breeds. are they junk? http://www.machinerytrader.com/listingsdetail/detail.aspx?OHID=7717323& hope this is not improper to post this way. i would like to buy and i am looking for issues.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42266 |
Posted: 22 Sep 2011 at 3:31pm |
The Caterpillar 312 hydraulic excavator was introduced in 1992 in Japan and France.
The 312 has a Cat 3054 turbocharged, diesel engine producing 84 flywheel horsepower (FWHP). It comes standard with a variable flow hydraulic system with a power and work mode selector, pilot activated control, horsepower summation control, high level of operator comfort, large cross-section design for the boom and stick, modified X-shaped carbody, increased stick and bucket force, and increased pressure in the travel circuit. The 312 was manufactured in Japan, with a 6KG or 7DK serial number prefix; and in France, with a 6BL prefix. Production ended in Japan in 1996; it was replaced by the Caterpillar 312B. Based on data from the sales database of Ritchie Bros. Auctioneers, it is estimated that more than 11,700 Caterpillar 312 hydraulic excavators have been produced. |
Tony.Or
Posted: 22 Sep 2011 at 4:46pm |
Call around and check on parts before buying , Cat may be only source for parts, also make sure it isn`t a grey market machine repainted & decaled. Tony
Ages Cat
Joined: 12 Sep 2009 Location: Hutchinson, MN Points: 700 |
Posted: 22 Sep 2011 at 5:06pm |
It may be worth your while to run oil samples on the engine and hydraulic system. An excavator with metal in the hydraulic system can be a real bad situation. A friend is a used equipment manager for a very large John Deere construction store group. They had a Hitachi with pump shavings in the system. Whatever they tried to clean the system did not work. I think it became a parts machine.
Coke-in-MN
Posted: 23 Sep 2011 at 8:03pm |
friend had JD hoe and estimate to rebuild hyd after metal was found in oil samples was $20,000. machine was not worth that so he has it for parts and bought another one similar.
farmer0_1
Posted: 23 Sep 2011 at 10:44pm |
great idea on the oil sampling on the engine and hydrualics. my next door neighbor had his 1266 int pump chips thru his tractor and sold it for the engine. keep them coming.
