Exact location HD14 Serial Numbers?
blackout dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blackout dozer Quote  Post ReplyReply Direct Link To This Post Topic: Exact location HD14 Serial Numbers?
    Posted: 05 Jan 2019 at 2:09pm
I know that an old post was asking the same question a few years ago but did not answer my question. Maybe someone can add more light. I have a 1939 to 1941 AC HD14 dozer with a Baker Hydraulic 10.6 wide blade, and a Pacific Cargo winch.
How many numbers or digits(serial numbers) will be on the (right) rear of the transmission? Are the numbers to be found on the end of the transmission on a flat surface or are the numbers located someplace else (right side) possibly on a more rounded area.
I know this is a long shot. Thanks for any information you may have that might help me.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2019 at 2:46pm
The serie number should be on right side stering cluch housing but with the winch  the serie number is mask.
Post Options Post Options   Thanks (0) Thanks(0)   Quote blackout dozer Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2019 at 6:00pm
Thanks I think the winch may be blocking the number too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote blackout dozer Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2019 at 8:36pm
uploads/19270/IMG_20190105_180927_2.jpg
This a picture from my manual.
Post Options Post Options   Thanks (0) Thanks(0)   Quote blackout dozer Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2019 at 10:37pm
I got the answer I was looking for from New Zealand. Where most HD14's have their serial numbers on the right, mine is a horse of a different color (US7) and is located on the left.
If someone says "It's Impossible" that just means it's going to take a little bit longer.
This page was generated in 0.227 seconds.
