eric's 1955 wd45 |
Page <123> |
grateful1micelf ![]() Silver Level ![]() ![]() Joined: 08 Sep 2015 Location: Oklahoma Points: 103 |
so here's what i came up with..i drilled out the piece of the old pin that was in that hole, then took a piece of key stock tapped it into the hole, then i had to cut it and file it to length and proper width to fit the slot in the housing. tapped it into place, and now that shaft will not spin anymore. so, i'd say success!
1955 WD45 (1st and only tractor i've owned..for now)
sandman2234 ![]() Orange Level ![]() Joined: 21 Feb 2013 Location: Jax Points: 2547 |
Just to let you know that your not talking to yourself alone. I just don't have the answers and figure someone a lot smarter will soon chime in.
Keep up the good work! David from jax |
A proud member of the Allis Express movement!
Northeast Florida |
it's all good bud. thanks. sometimes i just need to get on here and ask, then when i get no answers, i just go figure it out. pto housing is back on tractor, hydraulic pump is remounted. i just need to reconnect all the lines and hoses. i got new hoses for the lift since the old ones were pretty ugly. everything i removed got cleaned, sanded and fresh paint. i'll post some pics after i get it all back together. also bought me a cheap engine stand. ordering a full engine gasket set is next on my list. |
so, i got just about everything on the pto and hydraulics put back together. unfortunately the seal in the pto housing leaks, so i have to get a new one..lesson learned, plan on putting a new one before reinstall..but other than that, i think i'm gonna be back in biz. i'll get a lesson on bleeding the lines and adjusting the lift controls, but i'm just pretty pleased that i could get it all back together. thanks for everyone's help and advice. what do you guys think of the IH white on the clutch cover and lines?? interested to see if people think i'm out of line changing up the orange. my plan is to accent most of the covers and trim stuff in this white. curious to see what you guys think, good, bad, indifferent, all comments welcome.
![]() ![]() Edited by grateful1micelf - 02 Nov 2015 at 1:53pm |
ac45dave ![]() Orange Level Access ![]() ![]() Joined: 23 May 2015 Location: SE(IN) Points: 1346 |
need to turn hand clutch cover 180.there's a spring that goes from the hole on the ear to the sensing lever.
Edited by ac45dave - 02 Nov 2015 at 10:30pm |
I KNEW IT!! lol. thanks dave. i thought i might have put that cover on wrong, i couldn't remember what the heck that hole was for. i must be missing that spring because there was no spring in that hole when i started. none of the traction boost stuff was connected when i got this tractor either, except for the hydraulic line from the gauge to the pump, so i'll have to do some figuring and testing to make sure i get all that working again. Edited by grateful1micelf - 03 Nov 2015 at 6:36am |
so i got my new pto seal and put all that all back together. pto is functioning properly now! in testing the hydraulic lift, i found that it won't raise and lower now. i've seen posts that talk about bleeding the system and different things, but can't seem to find where i read that stuff. anyone have any advice on what might cause the lift to not operate? it doesn't seem to want to do anything at all?!? thanks for any help
-eric |
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6081 |
First some notes- The pump is a piston pump... the main shaft has lobes, which act on followers, and the followers push on the pistons. There's an unloading mechanism in there when pressure gets too high.
Transmission in neutral, engine running, clutch out, implement lever down, stand on the arms and force them down. If they won't go down, then the hold valve is either stuck, blocked, or otherwise not right. IF it happens to be full of air, when you stand on the arms, they'll 'bounce'. If so, back off one of the cylinder lines, stand on the arms, let the air out. Leave it loose for now... When the pump operates, you will 'hear' it talk. With the implement lever down, it probably won't make any obvious noise. Once you flip the lever up, you'll hear it start to work. If it has air in it, it may sound a little ugly, but eventually will draw fluid and start trying to lift the arms. If you've left the cylinder hose on one side loose, you may hear air hiss out, may even have oil leak out. Let a little leak, then half-snug the line. The arms SHOULD come up. Once up, the pump will load up, and then you'll hear the unloader mechanism shut the pump off. Stand on the arms again... are they bouncy? Lower the lever, arms SHOULD go down, and in doing so, a fair amount of air in the cylinders SHOULD get forced back to the reservoir. Your reservoir level will drop, so be prepared to add more oil. Cycle it a few times that way, and check level again. My experience has been that on a freshly assembled system, I've had to bleed them a little to get the pump to draw, but once the pump is moving enough fluid for the cylinders to raise and lower, these things seem to bleed themselves really well. Oh, and also note, there are different ways that the lift system can be set up, and the valve has several adjustment points that need to be set in order for the lift to do what you THINK you want it to do. My experience has been that no matter HOW I set mine, it NEVER does exactly what I want it to... it either wants to be full up, or when I run it full down, it will eventually raise it back up again... and if I try to set it partway down, it raises up again anyway... ![]() The complicating factor is also a linkage that's connected to the implement coupler... it's the draft-control sensing linkage. I haven't had mine apart, but I imagine that if this linkage is worn or wonky, that pump will do some funky and annoying stuff. My suspicion is that mine is wonky, funky, and annoying predominantly for that reason... Edited by DaveKamp - 29 Nov 2015 at 10:14am |
thanks dave! that is all very helpful info. my biggest problem, it seems so far, is that the arms don't lift at all. i thought they were stuck in the up position and wouldn't go down. upon further investigation, they simply won't raise. do you think it could be that i don't have enough fluid? i pretty much knew i was gonna run into these issues when i removed the pump to get to the pto gears, but really had no choice. it's all a learning process for me though and i have learned and still learning quite a bit. thanks again sir, for the good info.-eric
stu(ON) ![]() Orange Level ![]() Joined: 12 Sep 2009 Points: 377 |
I am late to chime in here, but a couple of thoughts.
You should be able to lift the arms from low to high with your arm strength. If not, what is binding? Packing glands too tight? You questioned on page one about the separation of heavy from light oil. You check the hydraulic oil at the bayonet stab inside the left frame rail ahead of the two pipe plugs for the heavy oil. You can tell on the bayonet stab if you have enough oil. Have you figured out how the chambers are separated? Do you have the operators and service manuals for your tractor?
"I am late to chime in here, but a couple of thoughts.
You should be able to lift the arms from low to high with your arm strength. If not, what is binding? Packing glands too tight? You questioned on page one about the separation of heavy from light oil. You check the hydraulic oil at the bayonet stab inside the left frame rail ahead of the two pipe plugs for the heavy oil. You can tell on the bayonet stab if you have enough oil. Have you figured out how the chambers are separated? Do you have the operators and service manuals for your tractor?"
i do have the manuals, i may not have when i originally posted this thread. i'm pretty sure i have the proper fluids in the proper places. i put 80-90 in the tranny and differential, and i used a light hydraulic fluid in the pto/hand clutch/hydralic (torque tube) area. what i did was pulled the hydraulic pump to access the shaft for the intermediate pto gear. the lift was working before, but when i pulled it, i had it in a few pieces and cleaned and painted it. i think i got everything back together properly. i'm hoping that i just don't have enough fluid in it yet and if i add more it start to work again. i don't have a full understanding of all the adjustments for the lift (delay/hold) but with the way i have it set up currently, i think it should at least go up and down like it's supposed to. i'll check the fluid again and add if needed, then bleed air if needed. i just wanted a lil' more input on the hydraulics before i tore something up. i'm sure my issue is something simple that some of you guys could figure out real easy. i just have to figure out and learn as i go. thanks again guys |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22006 |
The oil you put in the transmission and differential migrates back and forth between it and the PTO/hand clutch compartment. Those oils will get mixed as you run the tractor. The hydraulic compartment is by itself.
Eric, let's just make sure that you have this straight. The differential, transmission, wet clutch and PTO are all one big interconnected chamber. The hydraulic chamber is separate. There are two pipe plugs accessing the big chamber for heavy oil. The bayonet stab is the access for the hydraulic chamber that takes the lighter oil. Just wanted to make sure that you actually filled the chamber through this front port.
so no, i may have made a mistake. i was thinking the chamber in front of the hand clutch/pto was interconnected to the chamber w/the hand clutch and that everything after that was connected. so, yes, i put light fluid in the hand clutch chamber and filled the bayonet plug hole w/same light fluid. so i guess now, i have to drain the pto again and put the heavy fluid in there?? if so, do i also need to drain the tranny and rear end? i haven't moved the tractor since i put the new fluid in, so i kinda figure the lighter stuff hasn't migrated to the back end. or will it even matter that the lighter stuff is in the hand clutch chamber? if it mixes w/the heavy fluid it should be ok, or no? but, i for sure have light fluid in the hydraulic chamber that the pump mounts on the side of.
also, i just came back in from the shop. the lift seems to want to "spring" slowly back up when the lever is all the way down. i can push the arms downs by hand, but then they go back up on their own. but if i attach my plow, the lift will not lift it. and i haven't heard the pump "talk" to me or make any sounds like it's actually doing any operation. thank you guys for your patience and help, it's much appreciated. -eric |
I would not worry about the mxing of the two oils. Some fellows run hytran oil in all the chambers anyway. Unless someone has split the tractor in the past to replace the seal between the hydraulic chamber and the wet clutch, you will get some leakage & mixing anyhow. Just keep an eye out for any leakage from any external seals and top up with the appropriate fluid.
Make sure that the rubber dust cover around the gear shift lever is in decent shape, or you get water & dirt leaking down into that tranny chamber & beyond, which is not good, especially in freezing weather. |
shifter boot is in very good shape. i've only had tractor for a couple of months, so i really have no idea what work has been done to it before, but it has not been split since it was all working. i'm pretty sure the foot clutch is all the way back, but i will double check. for now it's inside so i don't have many weather issues to worry about. i already spent time fixing cousin's wd45 after he left the top of the shifter completely off for like 3 years! so i know all about keeping water out of there
![]() -eric Edited by grateful1micelf - 29 Nov 2015 at 9:00pm |
Hmmm... kinda sounds like mebbie the hydraulic pump control settings are in between 'modes'.
There's a spin-out knob, and a turning sector. The turning sector is the 'hold position' valve, and the rod must be adjusted properly, and the turning sector must be either engaged or disengaged according to the operating instructions for the operating mode you desire. The pump's check valve may be stuck open (passing fluid right back to tank), or the check valve adjusting screw may be set wrong. Check the hold position valve settings as noted in the operating manual... there's pictures posted in the other 'hydraulic lift problems' type threads. |
Dave H ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Central IL Points: 3591 |
That nail trick is also described in the service manual.
Eric, there is one more question before you start to read all about the hydraulic system and its controls. I don't remember many details about the Hold Position Valve, as I never touch mine.
However, look at the picture in your post of 2015-20-17 and the position of the lever screw and cam shaft. Then look at the picture in your post of 2105-11-02. I can't even see the screw. Is it assembled incorrectly after the clean up and paint job? You say it worked before, so I assume you want it reassembled the same way.
stu- the hold position valve screw is now painted black, that be why you cant see it. it is run all the way out to the stop though. BUT, you do have me lookin at my old pics. i have more pictures and i may look back through those and compare to how it's set up now. i just assumed i had it all hooked back up right, so i didn't even compare it to the "before" pics. good call bud. i do know that i'm missing the spring from the wet clutch cover to the control lever, as someone pointed out to me. but it wasn't ever there before when the system was working. thanks again -eric |
That's a different screw. Look at the parts explosion in the back of the Operators manual.
i think i see what you're talking about. i had to move the pics closer so i could compare easier. |
Eric, I will take one more potshot at you. Your Hold Position Valve does not seem to be set up like mine, which is in Hold mode for brush hogging. I believe that you made mention of a plow. You seem to have snap coupler. If you have a mounted SC plow, your HPV was likely set up for traction control or booster. When you removed the hydraulic pump and controls, you disconnected the link arm between the SC Bell and pump controls.
Are you sure that you reattached it properly and have the HPV adjusted accordingly? I will not rob you of the enjoyment of reading all about this in the Operators and Service Manuals. I cannot answer my own question.
yes stu, i believe you are correct. i noticed that i have a few places where i need to do some adjusting. one is where you're talking about, and i also think my linkage rods need adjusting, and i also left out the shims (washers) on the spring down on the draw bar, which i guess is part of the draft control. i'll make those adjustments and see if they help and i'll let ya know how it goes. thanks again for your help. this hydraulic system is one sensitive sucker lol..good times! ![]() ![]() ![]() |
Isn't it funny how we are always left wondering what the leftover parts were for?
You'll have the lift working better than ever by the time that you are through.
Page <123> |
