enough tractor???
skyhighfarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skyhighfarms Quote  Post ReplyReply Direct Link To This Post Topic: enough tractor???
    Posted: 08 May 2011 at 3:47pm
we are looking at getting a grain cart for this fall  (if it ever gets dry enough to plant something besides cranberries)  we have an ac 7020 and a jd 4430 both have duals and weights  and were looking at a killbros 490  500 bu i think  and a brent  472  ad says 450 bu but when i seen it in person looks as big as the 490  i was wondering if any used this similar combo out there  are ground is fairly flat  we use both tractors to pull killbros 385 wagons for now
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 5:56pm
We use a 7045 on a 450 bu. cart and no problems. We have a 7020 also but use the 45 cause its a PS. and the 20 is a PD. Either would handle it tho. We have 9 of the 60 lbs. front weights on to help with the tractors balance. Oh, and by the way, you're going to LOVE using the grain cart.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 6:58pm
Dad has used a 7000 in the past on a 425 bu EZ-Trail.  Does beter on the 7060.  Used the cart last fall on a 100 horse Massey and it did fine as well.  Just slide the drawbar short and stay off the roads loaded.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMB(wcIL) Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 8:02pm
Our JD 4440 fills in when needed on our A and L 475 BU cart does fine on level ground, I don't try to press the limits tho     Andy
This page was generated in 0.089 seconds.
