Engine will no turnover
 Post Reply Post Reply Page  <123
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2024 at 11:55pm
Sorry to see the valve dropped. Good luck on the engine rebuild.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2024 at 9:33am
Originally posted by Chugach Chugach wrote:
...  I am just glad I didn’t rip into the timing gear cover.
Yup, that would have been a waste. Obviously that piston did not move all the way upward when you disconnected the rod cap Ouch
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2024 at 11:14am
Hope the rebuild goes well. Please keep us posted. Thanks
Chugach View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chugach Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2024 at 12:33pm
Thanks I appreciate that!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chugach Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2024 at 8:35pm
When can dropping a valve still be lucky.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2024 at 8:46pm
if the top of the piston looks as good as the valve seat.... you might be in Business !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chugach Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2024 at 9:01pm
It has a few battle scars.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2024 at 9:06pm
Reckon the keeper didn't keep'er so very well Cry
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chugach Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2024 at 9:51pm
Many years of faithful Service. I am glad I had the key in hand when the noise started.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2024 at 7:13am
Check the rocker arm play on shaft
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chugach Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2024 at 12:34pm
Will do, thanks
