Engine vibration
Dennis(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis(IA) Quote  Post ReplyReply Direct Link To This Post Topic: Engine vibration
    Posted: 01 Sep 2025 at 9:17pm
I have had this tractor over 20 years and this year it seems to have excessive engine vibration, sometimes, when the throttle is halfway or more. I noticed it a couple of weeks ago. After that it seemed normal, then today ( bush hogging a small field) it seemed excessive.  This is without running the pto or anything.  I don’t know, maybe I am going crazy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2025 at 9:40pm
What model and gas or diesel ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2025 at 8:33am
Gas.  I know 4 cylinders vibrate anyway, but this seems excessive, I should remove the plate under the flywheel and clutch and have a look.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2025 at 8:35am
WD 45.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2025 at 8:56am
Tighten up the bolts that hold the engine to the bellhousing (4). Tighten up the bolts that hold the engine across the frame at the front (4).
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2025 at 7:58am
Crankshaft pulley bolt worked loose?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2025 at 8:09am
Good suggestions, I will check those bolts.  Simple things that need to be checked, thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2025 at 8:11am
Crankshaft pulley being loose usually causes a knocking sound.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2025 at 11:53am
Yeah, the knocking sound is what told me I had a problem. Had to be at the front end at idle to catch it. Wore the crank nose...turned into a $2000 rebuilt engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2025 at 8:19am
All bolts are tight. I put my big Channel lock pliers on the front pulley, and I thought I had some play ( the engine has a clunk) also.  The second time I tried it I did not see or feel any play.  Time to take the pulley off ( front seal is leaking ) and check things out.
Thanks for all the suggestions.
Another note is that I am hard of hearing, I wear hearing aids, but not the same as being able to hear.
Steve A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve A Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2025 at 5:36pm
I'm that way with the hearing aids too. Too much amplification with them in, wary of losing them. By the time an unusual noise is loud enough for me to hear its usually at the point of "Aw Sh_ _ " or buying parts.
This page was generated in 0.095 seconds.
