Engine Valves |
cjallis
Topic: Engine ValvesPosted: 03 Apr 2018 at 3:52pm |
How can you check if a valve or valves is stuck? I think some water got in the engine and some are now stuck. The engine is free now and I had new valves and springs installed prior to my roof leaking on my B.
What is the best way to free any stuck valves? |
Dick L
Joined: 12 Sep 2009 Location: Edon Ohio Points: 5092 |
Posted: 03 Apr 2018 at 4:36pm |
Remove the valve cover and push or pry each valve down and see that they come back up. Those that do not come up oil the stem and work the valve up and down until they move freely. If they were stuck in the full up position you would have a bent push rod to that valve.
rpropst
Posted: 03 Apr 2018 at 4:47pm |
Compression test.
1950 snap coupler B 1948 WD 1951Ca 1952B 1952adjustable axel B
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8667 |
Posted: 03 Apr 2018 at 10:21pm |
Dick has best answer so far...
cjallis
Posted: 04 Apr 2018 at 8:08pm |
Thanks guys. I used a clamp on each valve. They all compress down and back up again!
They seem a little difficult to compress though but maybe valves are supposed to have that much tension? Not sure? I sprayed the head and engine down with Fogging Oil and sea foam as well sand let it sit for a day. |
