Engine Upgrades |
AJ ![]() Orange Level ![]() Joined: 31 Oct 2010 Location: mo Points: 5244 |
![]() ![]() ![]() ![]() ![]() Posted: 17 Feb 2012 at 1:12pm |
Anyone know any tricks to get more power out of an Allis C? I know they aren't designed to have a lot of power but I was thinking a little more balls would be nice.
Can't fix stupid
CAL(KS) ![]() Orange Level ![]() Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
you need to talk to Dick L and read some of his previous posts. i seem to remember something about putting a D10-12 crank in a C and some other mods
Burgie ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Scottsburg, IN Points: 1192 |
Stick a D15 series II motor in it.
"Burgie"
allismanamp ![]() Orange Level ![]() ![]() Joined: 15 Oct 2011 Location: MN Points: 665 |
i seen a puller from Iowa that put a super charger of a 3.8 gm engine on his pulling tractor made great power to good actually case he broke the rim and tire right of the side of the tractor when he took off down the track had to drag it side ways to clear the track i would have been so embarrassed but that's part of it
If u put a D series engine in it do u have to put special supports on It to hold the engine or does it bolt in the same way?
Can't fix stupid
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21903 |
Easy fix? install a larger carburator from like a D15 or D15 II. |
BrettPhillips ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Strasburg, VA Points: 808 |
No special engine supports required with the 138, 149, and 160 engines. Having said that, I have seen 170+ cubic inch engines that were based on the 125 block. Probably 55-65 HP.
So if a person were to put one of those engines in an Allis C, one could consider that C to be one Mean Orange?
Can't fix stupid
Bolivar Boy ![]() Orange Level ![]() Joined: 27 Dec 2011 Location: wooster, ohio Points: 641 |
aj. you could tell everyone you have a C+ !
Ha!
Can't fix stupid
