Engine swap
Paulb66 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paulb66 Quote  Post ReplyReply Direct Link To This Post Topic: Engine swap
    Posted: 12 Mar 2026 at 10:26pm
Will an engine from a 190xt diesel work in a 7020 and if so how many things would I have to change like oil pan etc. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2026 at 10:37pm
A 7020 chassis requires a 7020 engine backplate and probably the flywheel. Front engine plate mounting ears will not reach the side frames, so some fab work will need to be done there as the front plates will not interchange between engine fuel systems and front covers/oil pans, etc.  XT oil pan and oil pump will work.  Water pump lower hose is on the wrong side, and I think the fan centerline will be an inch lower. Some creative lower hose plumbing might solve that or a water pump from an F or G combine. If the XT engine fuel injection pump is actually set at 94 PTO HP you will have about 84 PTO HP in a 7020 chassis.
Edited by DrAllis - 12 Mar 2026 at 10:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paulb66 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2026 at 10:56pm
Thank you for all the information I Definetly don’t want to go to all that trouble I’ll either get this one rebuilt or wait for the right engine to turn up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2026 at 11:53am
Fix the original and have something when done.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2026 at 6:47pm
I would look for either a combine engine of the correct size or even a 426 from a 7040 or 7045 tractor. They can always be turned down if you don't need the power.
