Engine shims?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: Engine shims?
    Posted: 10 Feb 2012 at 9:00pm
Where can I get a set of the shims for a CA engine bearings? That don't cost an arm and leg.Thanks Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2012 at 9:02pm
Tracy, Mine came from a roll of brass shim stock at work. I used a nice sharp shears and scribed out the shape. Didn't take as long as looking a number up and calling in my credit card info:)
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2012 at 9:09pm
I bought shim stock here and the thin stuff can be cut with a scissor.
http://www.smallparts.com/shims-shim-stock/s/16413251/ref=gn_m_sh
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2012 at 9:15pm
Tracy a good friend of mine gave me some pieces of shim stock and I made mine for one of my b's. I used a piece of steel tubing and used a shell case chamfer tool to sharpen the inside and stamped them out. He gave me 3 different thicknesses and I marked each thickness with a different color of sharpee to keep track.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2012 at 10:24pm
I have the shim stock. You used to get that set with the gasket and bearing. They were laminated. I am getting lazy. Thanks Tracy Martin
Wes (VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2012 at 10:58pm
I thought! you Tracy, of all people should know/have shim stock being in your line of work!  lol   -Wes
Wendell(OK/TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wendell(OK/TX) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2012 at 11:48pm
Sandy lake still had them a few years ago, seemed kinda pricey though.  Good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2012 at 11:57pm
Wendell, pretty sure I have them if I can find them. Tracy Martin
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2012 at 6:46am
I can have a set ,drop shipped to you with shipping .For  $30.00 ( main & rods ),is that worth the time to make them .When I do a motor job ,I guess get them with the kit .They could be sent to you monday ,with just a call to supplier and your address .
Edited by Fred in Pa - 11 Feb 2012 at 6:50am
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2012 at 2:35pm
beer can and sissors!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2012 at 3:02pm
Fred, I may call you. Thanks Tracy Martin
