Engine serial number decode
blue924.9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Topic: Engine serial number decode
    Posted: 13 Feb 2023 at 8:42pm
Can anyone confirm this is a d17 engine
hi my names dan, I am a young guy. i have a problem, i prefer my tractors orange and my clutches mechanical, thanks for letting me share
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2023 at 8:55pm
17- prefix indicates that it is…
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2023 at 8:56pm
here are a couple serial numbers to help you narrow down the year of the motor...
Edited by steve(ill) - 13 Feb 2023 at 8:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2023 at 9:33pm
If it is truly from a D-17 tractor, the letter on the end of the s/n will be "M" and I can't see what it is for sure. A tractor engine will not have a hole in the block below the engine oil filter for a fuel pump to attach. If the letter code is a "Z" and there is a hole for a fuel pump that is covered with a plate, that engine is from a Gleaner model "E-3" or a late model "E".  M code is 7.25 to 1 compression ratio. Z code is 8.0 to 1 compression ratio.
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2023 at 6:17pm
Thanks all for the help. It is indeed an m code engine. Until it was pointed out that it was a 17 I thought the first marking was a z
