Engine break in oil
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2017 at 6:16pm
Interesting article that is dated 2012, I noted the newer specs mandated by API to meet new standards set forth by the government recently.
For the end user, just make sure whatever you use meets your equipment spec by age and type of engine.
At the end of the day, a good sample will tell you what you need to know.
ACjack View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACjack Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2017 at 6:47pm
I toured the Harvey engine plant back in August of 1980. Engines were connected to a dyno (multiple dyno's and multiple engines in one room) and engine was fired up. Oil pressure was verified. Oil leaks were looked for. I suppose it was allowed to reach operating temps and THEN THEY POURED THE COALS TO IT!! engines were under full load minutes after fire up, and I doubt very much any special oil was used.
The oil that they used there was Shell Rotila and I believed it was straight 30w.
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2017 at 6:59pm
Folks, I am not a motor engineer but have out of personal necessity rebuilt s few.
For you folks that think an engine has to be worn/broken in, think bout this.
if you do it like me and put the oil in that your are going to use all the time and drive it like you do when you always use it, then you can drive it forever after and it will never get broken in - - just like new neigh!  LOL
Orange4ever View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange4ever Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2017 at 7:51am
When we rebuild a motor we never put in antifreeze we always put in water . use Rotella either 30w if it's in the summer or 15w40 for winter . We always put the oil in with a hand pump would go into the block oil Sending unit . for oil to get in the bearings and oil passages before running . Crank it over without starting it till oil comes out the oil sending unit hole . Start it get to operating temperature make sure everything is OK hook it to the big brush hog and let it run ,about every hour change engine RPMs i've let them run for 10 hours I've let them run for five hours depends on what time of the day we get it up and running we don't use antifreeze because antifreeze has a little powder in it and if it leaks out around the head gasket it'll keep the head gasket from sealingl . water will evaporate .head gasket Will seal at operating temperature. Everything checked out OK we change the oil filter! and put antifreeze in it and put it back to work . yes we let it cool before we put in anti-freeze we also put the sending unit back in the block before we start the motor DAVE
If you want a man to be a successful farmer, give him a Allis Chalmers tractor. If you want him to be a successful mechanic, give him a John Deere
oldways View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldways Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2017 at 12:26am
Everytime there is an oil topic I get more confused. Back in December several people were saying to use valvoline VR1 racing oil 30W in our older tractors. Because of the zinc. So I was gonna use it in my B. I plan to now with. So... Is this good or bad ?
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2017 at 4:38am
Personally I don't think it will matter. I don't know the detergency of that oil, which would matter to me. You don't want an oil with low detergency sloshing around in an older cooler-running engine. Sludge matters. I don't think you mean 30W. The 'W' indicates it's a winter oil, which SAE 30 is not. My previous employer, in Oregon where the winters are not that cold, used 15W-40 in everything up until a few years ago and I thought that oil was like syrup when it was cold. Those vehicles had lifter noise and oil consumption already as early as 75,000 miles. Most of your wear happens during warmup - this is where you want your oil circulating as quickly as possible. The old adage of thicker is better isn't true anymore. Perhaps down in Western KY 15W-40 would be fine, but I wouldn't use it in the northern states. As for zinc, I don't think it will make a huge difference, especially if you only use your tractor a few 100 hours a year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldways Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2017 at 1:14pm
SAE 30 is what I meant. Yes. 30 weight is what I meant to type.
