? Engine block heater
Bill Deppe/AC Salvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Deppe/AC Salvag Quote  Post ReplyReply Direct Link To This Post Topic: ? Engine block heater
    Posted: 21 Nov 2015 at 9:59am
What is a good brand and model for a engine block heater for a 301 engine? Have a AC180D that I would like to install a plug in unit
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2015 at 10:36am
my 180D came with a "kats" brand heater, I plugged it in once and it didn't work, so I replaced it with a new one, and it still don't work! then I gots a magnetic one that clunks up on the oil pan, it heats the oil good, but still wasn't nuff to help it start, need a good water heater one like you want! I like the ones that come on the 7000 series tractors, don't know if they are available for the 100 series tractors or not!
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2015 at 9:39pm
There is a freeze plug on right side of block for a factory AC heater. Not cheep but good.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2015 at 5:09am
Try one of the universal "coffee pot" heaters, that draw from the block drain, and dump hot coolant, into the thermostat bypass hose.  Used to have one on the old D-19, not a 301, but same general shape.  If you want to do it sans plumbing or electric, a Perfection 500 kerosene wick heater slides right under the oil pan...
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2015 at 6:49am
Agree 100%
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2015 at 1:26pm
The block heater is the same for example on both a 180 and a 7020.  The one on my father's 185 warms it up really nicely in an hour or two to make for easy starting in cold weather.  It's the original one and still works great today.  If you want to put a heater on, I'd get one from AGCO or a similarly designed one that goes in the block.  301 blocks have a heater with a flange and gasket and two bolts that hold it on the engine. I think that 426 blocks have one that's more like a water heater element in that it screws into a threaded hole in the block.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2015 at 2:17pm
Essentially the 426 and the 301 block heaters are the same, they just mount differently, and one has a 90 bend in it.  No they are not EXACTLY the same element, but close enough for this discussion.
They work really well, and you should be able to pick one up from about anywhere, as they are all over the aftermarket.  We run the Katz heaters on our 190XT's, only because they were there since long before my time, but like I said the OEM one will work great also.
Still in use:
