engine bearings and rod bearings
Kevin210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Topic: engine bearings and rod bearings
    Posted: 07 Jun 2025 at 9:25pm
Doing major overhaul on a 220 and was wondering
what engine kit or what brand of engine bearings you guys use
or recommend.
Also what piston rings would you use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2025 at 12:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2025 at 12:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2025 at 7:30pm
I've got a 220 project sometime this summer that a friend has with a scored piston from a recent OH (hour wise) by someone else. I plan on dropping the pan and pulling the cylinder head, remove all pistons to find the one that's scored, replace it and remove the other five sleeves and have them honed .003" to .004" larger to prevent this from happening again.
This page was generated in 0.111 seconds.
