Eliminating the traction booster on a 6080
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Topic: Eliminating the traction booster on a 6080
    Posted: 17 Mar 2017 at 1:57pm
If a guy wanted to bypass or eliminate the cussed traction booster on a 6080 how would you go about it? I thought about putting hydraulic coupler on the line going to the lift cylinder and run the 3 pt lift cylinder of one of the tractor's remotes. Don't grasp why you engineer something that requires two levers for the full range of motion.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2017 at 8:26pm
If I'm understanding this right, just unhook the Traction Booster linkage the the 3 pt movement is all up to you
ctbowles 58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles 58 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2017 at 9:07pm
push the leaver down on the floor by the right side of the seat and it should disable it.
H Clark View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote H Clark Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2017 at 4:02pm
The external cylinder is just an assist cylinder. It also has a cylinder built inside.
1960 D-12,1948 WC, 1973 160, 1977 175, 1984 6060
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2017 at 9:55pm
Leave Traction Booster all the way back and use full range of Position control lever for hitch up and down.
