electronic ignition
Solarone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Solarone Quote  Post ReplyReply Direct Link To This Post Topic: electronic ignition
    Posted: 01 Apr 2021 at 2:48pm
People is there a particular model of electronic ignition that works for the continental 4 or specs that are needed ? Thanks ! And oh yes took advice and switched alternator to Denso mini. You guys saved me some aggravation so thanks again !
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2021 at 3:32pm
Many are using Pertronix... Couple vendors on this site sell them and offer HELP if you have problems.
Edited by steve(ill) - 01 Apr 2021 at 3:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2021 at 3:42pm
Steve might be one of your NEIGHBORS ! Wink
Edited by steve(ill) - 01 Apr 2021 at 3:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2021 at 6:12pm
Frank,
For the correct electronic kit for your application, we would need the Distributor P/N off the tag of the Distributor. (if its still there)  Also, would need the type of Continental engine you have along with the model of Tractor. If you have a Model G with the N62 Continental on 6V's, we have the E.I.'s in stock. The E.I.'s come in 6VPG, 12VPG, & 12VNG. If you have a G, we have a "how to" on our website on installing an E.I. and it happens to be in a Model G.   HTH
Steve@B&B
bb-customcircuits.com
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2021 at 3:54pm
Have them in a OneNinety and D-19 and they work great
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2021 at 10:36pm
I put one in a 1960 f-600 with the 292,,, I sure didn't want to mess with points again due to the location of the distributor,,, yea... not one of
ford's better ideas....works great
This page was generated in 0.375 seconds.
