electrolysis issue
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Topic: electrolysis issue
    Posted: 28 Sep 2010 at 8:16am
so I am using a 12v battery charger.  My sacrificial anodes are two, each approx 24" long, 1" wide and 1/8 thick strip of steel.  About half each is submerged. The part to clean is a picee of angle iron approx 2x2x60",  Half of it is subermerged.  Im drawing too many amps. Battery charger cuts out.... So I am using one anode and not getting the complete coverage I want..  Is there a battery charger that limits the amount of amps it will put out?  In other words set it to 10 amps and no more than 10 amps will be used no matter the number of anodes...
Side note. I am using lye...notice that the rust settles on the botton and does not float to the top... I can see the part well thru the whole process.
Robert Mull Georgia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert Mull Georgia Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2010 at 8:33am
Use a weaker solution( Watered down). I used AC/DC buzz box welder set on DC 40 amps the last time I did it. Doesn't take but about 4 hours. Solution does get warm!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2010 at 8:45am
That may be the issue; I did put a lot of lye. will water it down. Thanks!
I just remembered I have one of those Lincoln welders too...but no 220v outlet...
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2010 at 9:41am
Robert....You have a suggested solution ratio?   Tom...What lye ratio did you use? Thanks....Dale
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert Mull Georgia Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2010 at 9:45am
The solution I used was the washing soda stuff. You have to use enough to make the water conductive.
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2010 at 9:47am
Tom, When I first read the title to your post I though you might be having a problem removing leg hair. LOL
http://www.hairlasers.com/electrolysis.php
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2010 at 9:49am
[QUOTE=Jeff Z. NY]Tom, When I first read the title to your post I though you might be having a problem removing leg hair. LOL
http://www.hairlasers.com/electrolysis.php[/QUOTE]
Well your in good company with the female co-workers I talked to about this....(funny how their eyes just glaze over)
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2010 at 9:50am
three bottles in 50 gallon...how much in each bottle....ummmmmmm?
Lot of sizzling and crackling going on!LOL!
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2010 at 10:07am
Tom , try this one,
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2010 at 10:30am
[QUOTE=R Aiken]Tom , try this one,             [/QUOTE]
Not much there I didnt already know other than the soda to water ratio. My process DOES work, just having a high amp draw.
I disagree about the bubbling reaction will stop when rust is gone. I have had a small part in for 24 hours and still bubbling even though its all black.
CJohnS MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJohnS MI Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2010 at 11:39am
Lye is caustic on its own.
The electrolysis process works best when washing soda is the electrolyte.
The greater the distance from electrode to workpiece, the greater the resistance, which will drop the amperage draw.
When a part has given up all the crud, rust, paint, grease, etc, the bubbling drops off dramatically.
Lye & electrolysis DOES NOT MIX.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2010 at 11:46am
Mixed well for me...getting nicely cleaned up parts; paint falls off,rust turns blak.....so not sure what your getting at
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2010 at 12:02pm
Tom:  Try putting a battery in line between the charger and the tank
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2010 at 12:07pm
If it comes to that I will try it. Thanks.  I suspect my solution is just too strong...
Think I will go to washing soda anyway because I am getting a bit tired of the extra precaution required... But I wonder why the crud settles instead of floats...is it the lye?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJohnS MI Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2010 at 12:15pm
Have never used lye. Typically, there's a floating crud layer, but all the big stuff ends up at the bottom. Some folks use a brick, or suspend the part so it doesn't touch the crap at the bottom.
100%, absolutely pure water is non-conductive. It's the other things that get into that change its resistance.
MBolton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBolton Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2010 at 7:13pm
Washing soda is soda ash is sodium carbonate is lye.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2010 at 7:21pm
lye is sodium hydroxide, not sodium carbonate.
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2010 at 7:52pm
Tom, if your welder is an AC machine, I don't think you can use it for that, and it could be very dangerous. DC is safer for this. Be careful.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2010 at 4:34am
Thanks Dream.  Dont think I will be doing a welder anytime soon. I was able to get my amps under control, I think diluting the solution helped.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2010 at 6:46am
Just an FYI, AC will not work at all, the current must be one direction to accomplish anything
I am still confident of this;
Wait for the Lord;
jjrosty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjrosty Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2010 at 1:02pm
I would check to make sure you didn't have a short.
This page was generated in 0.660 seconds.
