Electrical issue |
Post Reply | Page <12 |
Author | ||
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8075 |
Sometimes it's wise to pay an electrician for things like this. I know just enough about electrical to be dangerous.
Sponsored Links | ||
tadams(OH)
Orange Level Access Joined: 17 Sep 2009 Location: Jeromesville, O Points: 9773 |
Sounds like a loose screw on one of the connections. I had a problem with kicking a breaker at a out building that had a 100 amp box it was the screws on the breaker in the main box that was feeding it. But there should be a ground rod at every box.
Dusty MI
Orange Level Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5053 |
Depending on where in S.W. MI. I could maybe go and look at it.
I'm In the Charlotte, MI. area south of Potterville. Dusty
FREEDGUY
Orange Level Access Joined: 15 Apr 2017 Location: South West Mich Points: 5391 |
LMAO !! That's EXACTLY What I am towards electric AND mechanical work !! Yes, I am going to update any resolution to the problem !! Thanks again to ALL posters !!
DaveKamp
Orange Level Access Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 5652 |
This was my point- NEC 'suggests' single-point grounding at the point-of-entry, which most inspectors will say is at the METER, but in an agricultural scenario, that would result in many instances of several-hundred-feet of overhead triplex needing an additional grounding conductor... and of course, any time a building hosted an atmospheric discharge, it'd invite a 'multi-point fire'. So, basically, any sane agriculturalist would bury a ground stake at the building or grain bin. But this is simply a case of open neutral. A technical note- the meter used, is probably high enough input impedance so as to not register a significant difference in unladen circuit resistance if the local ground was tied to a highly-resistive neutral... or in less-technical colloquial verbage... the meter is so sensitive, that it wouldn't be able to notice a bad neutral until you put a 120v load on it... which is why you see what appears to be 'good' voltage until you flip a breaker. That bad neutral could be anywhere from the panel, back to the main, so be prepared to open many boxes. I wish I was there, with a big screwdriver... I'm certain I'd find it in a few minutes. Most of the world's most confusing electrical problems are the result of open neutrals. |
FREEDGUY
So do I,
SteveM C/IL
Can't decide if Dave want's to tighten screws or short across things....
JC-WI
Orange Level Access Joined: 11 Sep 2009 Location: wisconsin Points: 33703 |
Well, if it fries off the end of the screwdriver, you know you got juice there... liquid molten metal for a few seconds...
FREEDGUY
I must admit that the original wiring was done by dad in '72 (with a different breaker box) but all of the boxes;recepts' and switch boxs'; are metal and were exposed to a farrow-to-finish operation for 25 years, Dad has an electrician coming to the farm tomorrow so I hope to have an update.
