Electrical Grease ??
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Electrical Grease ??
    Posted: 24 Aug 2019 at 6:26pm
Dad and I will be retrofitting 6 gauge wire for 4 gauge from the breaker box to the FF axial fan/heater unit tomorrow, were advised to "dip" the ends into grease ?? The 4 gauge wire is braided aluminum. Is this something special or can I put a few "pumps" of bearing/suspension type grease on the wires ?? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2019 at 6:40pm
Noalox (sp) is a special grease used on aluminum wire to prevent corrosion especially when connected to a different metal. Chassis grease might help a little but is not recommended. Is the 6 guage wire copper or aluminum? Make sure you have enough wire capacity to carry the current load or you are asking for trouble. I won't use aluminum wire unless I have to do so.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2019 at 6:55pm
The 6 is copper but have been informed that the 6 gauge/60 amp breaker is the "minimum" combo for the 220/ single phase motor. Dad has 100' of "primary"wire that was pulled down from a previous project (2 blacks and a bare ground) that we will utilize 30' of the black wires and utilize 1 of the 6 gauge wires for a ground/neutral.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2019 at 7:21pm
Called Dielectric Lubricant. Used it with plug and play lighting on trucks, minimizes corrosion, maximizes clean contact, resists breakdown from heat and precludes much of the electrolysis action(Making a battery) between two dissimilar metal types, usually Tin or Tin Soldered Brass or Copper and Aluminum.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2019 at 7:25pm
Noalox is s brand name. What is called is anti-oxidating grease/paste is required when terminating aluminum (AL) wire. Never allow copper (CU) and aluminum wire touch/come in contact.
The National Electrical Code (NEC) requires that AL wire be one size larger than CU. From my experience of repairing problems with AL wire I think I would go two sizes larger, especially if the wire is being pushed to maximum limit. Best thing, don't use AL wire, I've seen a lot of problems with it. But it is used a lot without a problem.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2019 at 7:29pm
Is there a copper wire rated for # 4??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2019 at 7:30pm
Triplex Feeder line can only really get in AL, then there is Primary wire, I only use Copper and 12 ga as often as possible for 120V, 4, 6, 8 ga for 240v circuits
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2019 at 8:44am
I have done this several times, but I go ahead and replace all 3 wires with the old black covered primary... I spray paint the last 3 ft of one wire WHITE to mark it as ground.  Feed to outbuildings, feed to welder, temp service.  Works fine. I have never used any grease, but recheck torque on the lug nut ends every 5 years.
Edited by steve(ill) - 25 Aug 2019 at 8:47am
irlbeck A-C'S View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote irlbeck A-C'S Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2019 at 12:36pm
As the others have stated use a anti oxidant compound. Brands such as noalox,penetrox,ox guard will all work. There are alot of others as well and its not very expensive. You can find it hardware stores, electrical supply stores, or the building supply places.
Here in FL we are able to get copper triplex. We use it in the corrosive beach environment..
Also here with the harsh conditions we use the grease on the threads of anything you want to try to loosen later....
Edited by irlbeck A-C'S - 25 Aug 2019 at 4:59pm
B,C,CA,(2)WC's,(4)WD's,(2) WD45'S, 45Diesel, (2)D12'S Series 2, D12 Hiclear,(2)D12 Series 3, HD3, D17NF (3)D17 Series 4 Diesels, M-100 Grader,8550,A few Lawn tractors lots of other AC stuff
festus51 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote festus51 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2019 at 10:50pm
Avoid AL wire if possible.  A lot of problems with it.   Wire will loosen up on terminals over time.
We the unwilling Led by the unqualified Doing the impossible for the Ungrateful
