electric drill's
Brian S(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian S(NY) Quote  Post ReplyReply Direct Link To This Post Topic: electric drill's
    Posted: 16 Jul 2019 at 8:54pm
my makita drill with manual chuck crapped out during a project and I have been trying to drill steel with my portable drill with the automatic chuck on it. The chuck keeps loosening up and spining on the bit.. :(  and when you get almost through the darn drill doesnt want to finish the hole. Do they still make heavy duty variable speed electric drills with a manual chuck?
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2019 at 9:20pm
As bad as it hurts me to say this I bought a 1/2” drill at harbor fright. It has lasted since 2011. I GM have drilled lots of holes (25000) in 3/16” purlins on one job. It has mixed a lot of tile grout and a lot of drywall mud. It has served as an electric starter on 2 different welder motors. And it’s drove a whole lot of timber locks and lag bolts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian S(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2019 at 9:43pm
and it has a manual chuck? I'll head there tomorrow
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2019 at 10:31pm
THe Dewalt titanium bits I bought have three flats and can't turn in the chuck there also sharp enough I can drill almost anything with an old B&D cordless drill.
Edited by Dakota Dave - 16 Jul 2019 at 10:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2019 at 4:46am
My favorite, right now is a ryobi cordless impact driver, with cheap HF unibit set.  The unibit drills have a hex shank, that snaps into the QD of the driver.  Still have an old B&D 1/2" manual chuck, for larger drilling, + a drill press, for the big stuff...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2019 at 5:04am
Yes
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2019 at 6:20am
yep my HF drills and favorite black and decker 1/2" that I cannot beat down all have manual chucks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2019 at 6:50am
I will have to look in the storage unit. I have a Milwaukee, corded , electric drill with a manual chuck that I haven't used in over 10 years . Battery drills just perform too good . I have a corded electric sawzall that hasn't been hardly used in just as long .
The bits that have 3 sides and won't slip are the only ones to use on a speed chuck.
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2019 at 8:27am
We use 1/2" Makita drills in the chicken house to turn winches and have had to rebuild them a couple of times. You can get new brushes for them and probably other parts I'm sure. If it were me I'd look real deep into rebuilding rather than buying new
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2019 at 8:49am
I HATE keyless chucks! They are handy but they suck all the same!
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2019 at 8:57am
But the keyless chucks are round, no jaw to grip the flat.  The keyless chuck was supposed to be a safety inventions, so you didn't leave a key in a spinning drill.  We're so safe we can't do anything now!Angry
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2019 at 9:47am
See if you can get just a regular chuck. ---That's what I did to 3 of the old drills I was given because the keyless chucks were junk. I tossed the chucks in the junk and found good ones to put on them. All you need is to match up the the thread size and it will work.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2019 at 10:08pm
i have a makita 1/2 18 volt drill , great drill use it very hard and almost daily i whent in to the makita dealer and we put a manual chuck with key , best thing i did,   we replaced to many of the keyless chucks , if you spin one bit in a keyless chuck they are never very good from there on out
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2019 at 11:38pm
I realize they can slip but it sure nice to use the keyless chuck when you have to change bits a lot.  For instance when drilling a hole in sheet metal then putting in a screw bit.
Allis Express participant
Ken(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2019 at 7:03am
I get where you're coming from, my biggest complaint with cordless drills is the chucks. ButKeyless chucks aren't the problem, cheap keyless chucks are. I have a Milwaukee 1/2" corded drill we use to hone holes with (up to 18" diameter) fitted with a good keyless chuck (probably about $200.00 plus) and it works great. You get what you pay for. For that matter, cheap keyed chucks are no joy either.
This page was generated in 0.258 seconds.
