Early 1950’s linoleum……… |
Post Reply |
Lars(wi)
Orange Level Access Joined: 14 Sep 2009 Location: Permian Basin Points: 7059 |
Posted: 4 hours 49 minutes ago at 6:14pm |
Being removed from hallway, and probably kitchen.
Was underneath 1980’s wood grain laminate made of some type of rubberized plastic petroleum product. The linoleum isn’t coming up easy. The black adhesive mostly remains on the hardwood floor. What’s the best course of action to remove this 70 year old adhesive? |
DMiller
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 30633 |
Be cautious with those, the Tiles in the 30s 40s and 50s had Asbestos in them.
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 80101 |
If they are 9 x 9 size, there is 100% chance of them being asbestos... If other size, and built before 1960, still some chance... As long as your scraping and its comeing up in CHUNKS, thats OK... DO NOT GRIND.. NO DUST...
BEST way to do it is to screw down 1/2 inch plywood OVER the stuff and START OVER.
thendrix
Orange Level Joined: 04 Feb 2013 Location: Fairmount GA Points: 4824 |
Don't know about linoleum, especially of that vintage, but a heat gun works wonders on peel and stick tile. Might be worth a try
Lars(wi)
This is actually rolled linoleum. Not brittle like the tiles. We want to try and go back to the hardwood floor.
i think the HEAT is a good idea... Most "GLUE" turn gummy when heated and can be scraped with a wood chisle or putty knife.
KJCHRIS
Orange Level Joined: 21 Dec 2015 Location: WC Iowa Points: 877 |
Lookup "Asbestos Abatement Procedure"
If the tile is that old it's very likely it contains asbestos.
My house built in 1955 has 1 room with the original tile on floor, the others are hardwood floors. At purchase I got a Notarized letter stating this 1 room has asbestos in floor. |
Coke-in-MN
Orange Level Access Joined: 12 Sep 2009 Location: Afton MN Points: 41471 |
In many cases if the tile were not asbestos , the glue contained it .
The remediation is to dampen it when scraping , There is a orange based glue removal product I got from a Janitor Supply company to remove glue from concrete where carpet had been glued down (glue was known as Green Death) as it seemed to even defeat a power razor knife machine . Product was expensive but result was clean floor once glue was scraped off , it turned into stringy paste and easily removed - then water washed floor . I had tried several solvents until I talked to my supplier on products to try , the stuff worked |
"Challenges are what make life interesting; overcoming them is what makes life meaningful." |
Post Reply | |
