early 190 eng oil cap. (I meant capacity)
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Topic: early 190 eng oil cap. (I meant capacity)
    Posted: 31 Mar 2010 at 11:49am
Is it different than the later 190's? My book is for a series III and my 190 is a 1965 model with the D2800. Thanks. Lonn
Edited by Lonn - 31 Mar 2010 at 6:22pm
Wink
I am a Russian Bot
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2010 at 12:19pm
The early ones had an expanding rubber plug, the later ones had rubber can that fit over the oil fill tube.   I dont know when the change was made Lonn.  I would say you should have the expanding plug, the fill tube didnt change so the rubber cap would work.  HTH
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2010 at 6:21pm
Sorry. I meant oil capacity. Series III says 12 quarts. Thanks. Lonn
Wink
I am a Russian Bot
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2010 at 9:14pm
The only change in capacity on the 301 would be related to the upgrade to the dual full flow filters (which I don't think happened until the 200) and the change to a crank mounted oil pump, which upped the sump capacity to 16 quarts with the 2 full flow filters changed (I believe the 2 full flow filters came with the crank mounted oil pump).  This oil pan has a big hump up front, where the older engines with the cam driven oil pump has just a more triangular shape that is lowest at the center.  If you google pictures of a 200, 7000, 7010, 7020, or 8010, you will see the newer style oil pan.  If you look at 180s 190s and 190xts, you will see the old style oil pan.  I believe the 185's production ran through the change, so they have both types, thus, aren't a very good reference.
Hurst
1979 Allis Chalmers 7000
5800 Hours
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2010 at 6:34am
Thanks Hurst, That's what I figured but couldn't remember for sure. I needed the tractor right away so I just went by the dipstick and 12 qts is what it took. Thanks again. Lonn
Wink
I am a Russian Bot
This page was generated in 0.106 seconds.
