Durst Gearbox
rjranch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rjranch Quote  Post ReplyReply Direct Link To This Post Topic: Durst Gearbox
    Posted: 13 Feb 2011 at 10:01pm
I am looking for a Durst A-11 gearbox , either in good working condition or for parts. I need the two gears ( B-33 and B-33-1)
Post Options Post Options   Thanks (0) Thanks(0)   Quote rjranch Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 7:14am
I'm told that these were common gearboxes used on grain augers?? this is a right angled box with the main shaft being 1 1/2" dia and the right angled shaft being 1 3/8" dia.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 2:25pm
Can you use a AC gearbox, one out here in barn that needs a new home[yours].
Post Options Post Options   Thanks (0) Thanks(0)   Quote rjranch Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 9:13pm
can you send me some pictures of the AC gearbox??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2011 at 6:49am
Yes, I will do it today and post here, I think it is pretty common RAngle drive used on different implements.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2011 at 6:58am
Picture added;
Post Options Post Options   Thanks (0) Thanks(0)   Quote rjranch Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2011 at 8:31am
Not quite what i'm looking for,  the Durst gearbox has a min shaft the run allt he way through the unit with the right angle shaft dieing in to the main shaft, all married togeher with beveled gears. This box is off of a tractor mounted snowblower so the main shaft needs to run all the way through to allow for the main impeller to attach within the blower houseing. Guessing you will not have a problem finding someone inhere that will give your gearbox a new home.
This page was generated in 0.305 seconds.
