Dumb questions
squirt239 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote squirt239 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2021 at 8:58am
Another question:
Before I got this tractor, someone had converted it to 3 point.
I was wondering if someone had a picture of the back of their snap coupler D14 so I can compare.  I just need to know how to use this snap coupler plow.  I'm thinking I need to remove the 3 point system...but I'm not sure what all needs removed.
Thanks again guys!
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2021 at 12:36pm
https://www.youtube.com/watch?v=7JNrK9DO_Zk
Edited by steve(ill) - 08 Apr 2021 at 12:44pm
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2021 at 12:44pm
https://www.youtube.com/watch?v=wWHS72kjUhQ
this is a factory movie from 1950..
Edited by steve(ill) - 08 Apr 2021 at 12:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote squirt239 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2021 at 2:31pm
I'm missing the latches on the lift arms 😔
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2021 at 3:56pm
Latches might be a little $$$ and harder to find.. You could probably use a pin / bolt/ bracket / homemade attachment to get by for now if your running a "TEST" to see how things work.
I actually have one small tractor that uses two chains for the lift links.. Allows them to flex, bend, rotate as needed.
Edited by steve(ill) - 08 Apr 2021 at 4:18pm
