duals on tractor ?
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Topic: duals on tractor ?
    Posted: 21 Mar 2012 at 8:19pm
im putting duals on my 7045 tomorrow for discing oats ground. mine are T rail type, how many hooks to use , is 4 per wheel  enough? how many do you use pre wheel ? looking for ideas please. it has 20.8X38 tires and duals
                           Shawn
Edited by XT in pa - 21 Mar 2012 at 8:29pm
190XT,D17and 7045
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2012 at 8:20pm
Most tractors with 38" rears use 6 hooks.  I've run 6 hooks on 20.8 x 38 radial duals  for 25 years with no problems at 150 hp.
Edited by Calvin Schmidt - 21 Mar 2012 at 8:55pm
BLee Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BLee Mn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2012 at 8:21pm
NO  4 is not enough,  4 is enough for a WD-45, but on a 7045 you better have at least 8
Cowboy UP
tony View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tony Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2012 at 8:34pm
Had a 2705 Massey (not my fault- dad & mom picked it, About 120hp) w/ 20.8-38 and we ran 4 clamps/dual w no issues.
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2012 at 8:39pm
i had T rails before on my 190 there was only 4  that came with it. i was useng a chisel plow (3pt 7 shank) and i spun the tires and duals didnt. i had to cut the boltsto get them off.im only pulling a 20 ft disc.
                    Shawn
190XT,D17and 7045
BradinNWWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BradinNWWI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2012 at 9:21am
We always ran eight clamps on our 8030.
Dan (SE MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan (SE MI) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2012 at 10:51am
We run eight on our 7045 with 20.8X38 tires.  Our 7000 runs four with 18.4X38s and has got along fine for years, put it always looked like it was not enough.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2012 at 11:30am
Never had a problem with 4 on a 210, 220, 8030, or Ford 8000
aras View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aras Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2012 at 11:35am
We use 4 on our 8050, 200 and only 3 on a 6080 once.  Make sure the valve stem is as far away form a clamp as possible because they may spin and become tighter.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2012 at 6:26pm
Eight is all we have ever run. The spinout wheels use eight wedge clamps.
Dale-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale-OH Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2012 at 4:14pm
Lots of tractors have run 4.  I would say 6 is ideal
This page was generated in 0.067 seconds.
