Dual Hydraulic Outlets |
rustyorange45 ![]() Silver Level Access ![]() Joined: 01 Sep 2013 Location: Vernon Co. MO. Points: 394 |
![]() ![]() ![]() ![]() ![]() Posted: 14 Oct 2016 at 3:09pm |
Everything is plumbed with hydraulic fittings.
1953 WD45 WF/Model 90 Loader, Oxnard Rear Blade, 80R Mower, Model 209 Disc, WD Rear Mounted Scoop, Model 184 & 160 Rotary Mowers, 1952 CA NF/L306CA mower, 1953 CA WF/Model 8 Loader.
AaronSEIA ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2573 |
Sounds good as long as everything you used is built to handle the 3500 psi or so of the stock pump.
AaronSEIA |
I just finished installing a 3 way hydraulic ball valve on my WD45. It allows me to raise my loader and valve it off and then I can use the lift cylinder for my mower . Really easy and I don't have to take my loader off when I use an implement with hydraulic lift. Use a 1/2" NPT 3 way ball valve, one 1/2" NPT nipple, two 1/2" NPT male 90*, and two hydraulic couplers. Plumb it into outlet of transport valve. Saves a lot of time and aggravation. Thanks to all who gave advice on this proje
