Dual 340 to big for 170 Allis?
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Topic: Dual 340 to big for 170 Allis?
    Posted: 15 Dec 2021 at 7:14pm
IS a Dual 340 loader to big for a 170 Allis? Just wondering if I should put it on.  See it has a mid mount bracket, with front braces and extensions to rear axel. Don't want to bust the tractor in the middle.
klinemar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2021 at 8:40pm
A lot depends on what you try to pick up. What size bucket? One item to remember is the front axle takes a lot of abuse from a front end loader!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2021 at 11:56pm
should handle it fine, and also what Klinemar says!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2021 at 3:28pm
Good reason for a heavy counterweight on the rear hitch of any loader tractor
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2021 at 10:48am
Need to use the area between the ears for more than a place to set a hat.Front ends on any tractor can be overloaded.
A friend has backhoe so the rear is loaded plenty. Citydot begged the use of it, tested it to the max. Both front tires where old and blow, instead of other harder to fix things.
So for safety load the back end but within reason. So if the back end is lite you know your overloaded.
This page was generated in 2.516 seconds.
