D-Series Headlights
mark/indiana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark/indiana Quote  Post ReplyReply Direct Link To This Post Topic: D-Series Headlights
    Posted: 04 Mar 2010 at 3:57pm
I am assuming sealed beams...need a couple for D-15 II..Need guts only..
Best place to buy?? Mark
mark/indiana..."My favorite Allis Tractor or Crawler is the one I'm sitting on at the time!!..
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2010 at 4:55pm
Mark
Assuming your D15 is 12 volt, if so remove the bulbs from your D15 and take one to your local auto parts store and they should be able to match you up with a pair.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark/indiana Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2010 at 6:52pm
New problem...how do you get them out after the snap ring is out???
Thanks in advance. Mark
john n/il. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john n/il. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2010 at 6:59pm
they might be stuck with crud but should pop out,just had mine apart,used a small screwdriver and pried a little
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2010 at 8:43pm
There is a hole in the side of the housing, stick something in that hole and carefully pry outward on it. They come out quite easily that way. HTH Rich
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark/indiana Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2010 at 8:52pm
Thanks, saw the holes, just figured it was an early weight reduction ploy..I take it that Napa or someone stocks the lights...Mark
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark/indiana Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2010 at 4:00pm
lights are out...two found at local Napa...thanks to all
GE/Wagner 4419 35 watt/ 12 volt..Mark
This page was generated in 0.153 seconds.
