Drop Deck Rollover: |
| Author | ||
Codger
Topic: Drop Deck Rollover:Posted: 11 Feb 2026 at 7:55am |
Little fun at the shop yesterday afternoon. Though I've replaced this trailer with an RGN unit, I've already purchased suspension hangers so will incorporate them with the improving weather. Last time I rolled this trailer over the weather turned sour on me by the time I could really get time to dedicate to the project. I've always liked this trailer since building it in 1983 from two wrecked semi trailers' parts so may elect to keep it after all. ![]() ![]() Something to do I suppose.
Edited by Codger - 11 Feb 2026 at 7:56am |
That's All Folks!
| Sponsored Links | ||
LouSWPA
Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25518 |
Posted: 11 Feb 2026 at 8:08am |
Like I always said, 'keeps me out of the bars at night'!
I am still confident of this;
Codger
Posted: 11 Feb 2026 at 8:48am |
Keeps me out of jail as I tell everyone around here.
That's All Folks!
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25096 |
Posted: 11 Feb 2026 at 8:55am |
gee, looks like you could plant a few trees ! The ground looks real flat and barren. least there's no snow though !
Codger
Posted: 11 Feb 2026 at 9:41am |
Shop property was the homestead for all the surrounding farm ground. I don't own any of the surrounding ground, only 2.2 acres the shop and house are located upon.
Snow finally melted off over the weekend so plenty muddy in spots. Saw several Robins in the tree out back this morning so spring is coming!!
That's All Folks!
Codger
Posted: 12 Feb 2026 at 7:41pm |
Got after the project pretty good this nice, warm day. Axels are ready to pick out tomorrow morning and I'll remove the rest of the suspension hangers after they are clear. Was only going to replace front hangers but discovered center hanger on one side perforated behind air tank so will replace both sides. Have the parts already so just a bit more time to complete the task.
First front hanger gouged off the frame: ![]() After removing the bases of the front spring mounts: ![]() Everything removed except axles themselves. I'll bridle and pick them out with the skid steer tomorrow morning. Then continue on with the task. ![]() |
That's All Folks!
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8901 |
Posted: 12 Feb 2026 at 8:08pm |
Are you gonna put parking brakes on it. Nice to have it stay still when hitching.
Codger
Thanks(1)
Posted: 12 Feb 2026 at 10:11pm |
Yes I am. Pushing back is not a problem with a couple of my tractors but my R model winch truck has a high mount 5th wheel and I have to either block the tires, or connect the air lines and pull the trolley valve down while backing under. You can't see in the photos but all four chambers have holes rusted through them. This trailer hasn't been off my property since about 2012 so setting quite a spell. I have new 30/30 spring brake chambers, good used air tank, and a new R-14 relay valve already so going to incorporate all while it's upside down. Brakes, hardware, slacks, wheel end seals are new and never used since install. Same with the king pin and plate which is 3/8". Brake hoses will be replaced citing age and jacket cracking. I saved back for many years a "Power Packer" hydro pneumatic landing gear setup I may use on this trailer also. The two speed setup installed now was new in the early 1970's and I repurposed it onto this trailer when built. I never really cranked it off a truck loaded so these have mostly been lightly used and never bent. Axles are repurposed from a 1950's moving van that was rotted to pieces. I'll get it gutted out over the next couple of days and blast clean before welding. I may use the same welder I built the thing with all those years ago as it's still in the shop sitting disused. I'm probably going to widen it to 102" width also. Right at 95" wide now and not going to split and section axles as don't want to do any frame work. Nice little project I've put off for a long time. I'd like to get this going strong before the weather turns consistently nice as I really don't have a lot of time to work on my own stuff then.
That's All Folks!
Codger
Posted: 13 Feb 2026 at 5:48am |
Pouring through both Euclid, and Dayton Parts catalogs and have most of the needed bolts and hardware listed. Have to do this as not quite certain the kids at the counter could find these old parts although still in common usage.
Need to order the rebound bolts, sleeves, nuts and equalizer hardware as didn't plan to originally go this far with refurbishment and will have them the first of next week. I've been planning to do this task for a number of years but grandkids started coming along and an already short allowance of free time was further reduced. Now they've far surpassed any knowledge I possess, so a little free time returns. |
That's All Folks!
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5169 |
Posted: 13 Feb 2026 at 7:28am |
When I took my road test for my Class 1 Chauffeur's license (now CDL-A) back in the 70's, we had to back up, hook the air hoses and hold the trolley brake when "hitting the pin". Failing to do that was an automatic failure. I had forgot about that until I read your post! Memories...
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5253 |
Posted: 13 Feb 2026 at 8:52am |
I wish you were closer, I have NEW spring perches for the 4 corners of a Hutch 4 spring suspension. Although they might each fit into FlatRateBox. I got them New to repair a trailer I have and them found a good price on a complete NOS air ride.
Codger
Posted: 13 Feb 2026 at 9:26am |
In Illinois it was a class "D" license for heavy combination vehicles then. Class "A" was for any single vehicle under 16K in weight except motorcycles. It is reversed with the CDL program which I was grandfathered into. I was in the line for the heavy license on my b'day 1978, but there was only a light pretrip and equipment checkover. Then of course the driving test. Nothing about the trailer except make certain your pin was latched by pulling with the trolley valve, and working lamps. I was in a then new and borrowed 352 Peterbilt and old 40' Fruehauf flat that did not have spring brakes. The trailer had chocks. Didn't know if they were required so set them into place before the test and the examiner watched me secure them into an underbody tool box as we were doing the pretrip. I don't remember setting them back into place at conclusion but it's been a while.
That's All Folks!
Codger
Posted: 13 Feb 2026 at 9:36am |
I thought about going with air ride under this one but already have all the Hutch stuff on hand so will use it up.
That's All Folks!
Codger
Posted: 13 Feb 2026 at 11:27am |
Being a firm believer in the power of "Slave Labor", I enlisted the help of my 14y.o. grand daughter to pick the axles clear and stage them while I drink coffee and watch:
![]() ![]() ![]() Will be a bit easier to work with now. ![]() |
That's All Folks!
Les Kerf
Posted: 13 Feb 2026 at 11:57am |
Not many 14 year old's can do that! I frequently conscript my 15 year old Grandson for similar tasks.
Joined: 11 Sep 2009 Location: illinois Points: 90136 |
Posted: 13 Feb 2026 at 12:47pm |
slave labor aint a bad job when you get to run a $10K Skid Steer !!!
Look like you got a GOOD HAND there for help !
WF owner
Posted: 13 Feb 2026 at 12:57pm |
In New York State, we had to completely unhook and re-hook. The day I took my road test it was sunny when I left home, but we had a cloudburst when I started my test. I thought the guy might not make mee unhook, but I was wrong. By the time I got back in the tractor, I was as wet as I would have been by jumping in a pool. Maybe he felt bad for me, but I passed.
Your "slave labor" will fondly remember these times the rest of her life. I bet Grandpa enjoys them, too. Grandkids are the greatest, but they grow up way too fast. My youngest granddaughter graduates from high school this year. It isn't like it was when they were younger.
Codger
Posted: 13 Feb 2026 at 9:02pm |
She is actually pretty good in that loader. Her first lesson was when she was seven so has a few hours in the saddle. I routinely let her drive the car a 21 mile stretch from a Pekin, IL to Farmington where my shop is located. It is mostly country roads, but not all; no city traffic. She does well. Did the same with my kids when growing up.
Also have had her blasting, (at low pressure) and she should be able to help with this trailer as it nears completion. Still a bit light in stature to be withstanding the "push" a blast hose imparts. What is neat is she really likes working with me for some reason?????
That's All Folks!
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35403 |
Posted: 14 Feb 2026 at 10:33am |
Reminded me of Days I lived, building Pipe Tongue Pups for Dump Trucks from old Semi Trailer sub structures. Personally built four, rebuilt enough cannot remember a number. Most were old four spring Reyco, or ended up with replacement Hutch or Reyco, only built a few on Air Bags. Built a Drop Neck Drop Deck back in 1978, MO SHP enjoyed beating me around on that one getting a DOR ID Number for it. Three trips to troop C one to Troop F after Tr C declined a Fourth. Inspector at F explained his compatriots were just jerking me around as had no clue what were looking at.
Tri Axle, Rear raised and lowered but At Rear control. HOBBS Axles actually made by PRO PAR, 16" Three Spoke Hubs Six Lugs each and wide flange two bolt Wedges. Changed to Grease Packed as Oil drew moisture. Neck enganearing was some real complex geometry likely did not need but was easy to connect or drop. Steel was procured and rolled at a steel yard in Earth City, Main Rails were 'Arc'd' by Fruehauf off Duncan St in ST Louis. When I got it done had lost my butt in labor but guy that needed it could not buy one as short as we built. Had close to 100# 7018 Rod in it. Deck was only 28', to suspension region, tongue was slightly longer than a typical and had a Higher Arch to it for off road clearance. Was attacked for Patent Infringement but as that was to go to Lawyers was found I had developed the Style of Neck Connection two years PRIOR to the other(Will Not Name) Company design, I just had no patent. Case was dropped. Same design is no longer copy right protected but has been dumped for far simpler designs. Some days think on returning to working HDT and Trailers, just no one wants to pay the going rates. Not giving away my time anymore.
Edited by DMiller - 14 Feb 2026 at 10:42am |
Codger
Posted: 15 Feb 2026 at 6:41am |
Those were popular with a couple of outfits in this area for awhile but seemed to have petered out. Same thing with xfer dumps that are popular in CA. Both went by the wayside several years ago. Never built a pole type pull dump trailer but worked on/repaired/rebuilt several being mostly suspension rebuilds. Picked a lot of cylinders, and valves also but those always went sublet for repairs. Reyco 101 series is a good choice for that work as very lightweight, and easy to maintain such as rebush when needed. Hendrickson, and Neway were also pretty good but more $$$ to keep functional when something went awry.
Used to see tag, and gooseneck type trailers in the shop with destroyed original "Dexter" type leaf spring suspensions fairly regularly. Always replaced with 7600/7700 Hutchens suspensions and not looked back. Were, and still are easily available/supported. Axels in the "light duty" replacement were usually "Lippert", or "Rockwell-American" as you could get wall thickness that wasn't going to bend/deform. Plenty of options out there but I seen more quality control issues with Dexter Axle than anybody else. That could have been the sheer number of those axles in service however. The axles under my drop deck are "Standard Forge" from a 1950's furniture moving van which I think was a "Brown" trailer. That van was used as a mobile tool crib until it was no longer safe to pull and I grabbed it when going to scrap. I purchased all the steel, and suspension new in the summer of 1983, and welded the trailer together in the off hours at a couple of different places I was working as they had bridge cranes available. Miss that kind of work a bit; but back then it was hard to keep working. Layoffs, plant closures, businesses downsizing were all too common for a young guy with a small family to find steady and rewarding employment. |
That's All Folks!
DMiller
Posted: 15 Feb 2026 at 11:31am |
Preferred the PROPAR and Rockwell axles years ago, Std Forge was sparse here Hutchens and Hendrickson more recent arrivals. SF was acquired by someone but cannot remember who. Most get shuffled like cards in a deck anymore.
Codger
Posted: 15 Feb 2026 at 4:44pm |
I never really messed with axles much on heavy trailers; mostly light, and medium duty units and again mostly Dexter. I don't remember ever replacing that brand with another of the same but usually went with Hayes, Alko, or Lippert axles without the spring perches welded on. Did that myself. I made a little gauge you could check spindle concentricity and offer/implement correction before permanent mounting. Many axles I cut the spindle assembly free from the tube and rewelded as should have been during manufacture. Sloppy tolerances is an understatement in some aspects.
That's All Folks!
Codger
Posted: 16 Feb 2026 at 6:41am |
Dragged out my portable garage which I blast in last evening to contain the residue. Granddaughter and I may erect it this afternoon but facing some time constraints with her visit today. Got a few more parts ground clean and removed, but ran short of cutting discs. Thought I had a new box but that box was empty. Have ordered more online so a few days postponement on this project.
That's All Folks!
Codger
Posted: 19 Feb 2026 at 10:13pm |
My heavy equipment operator returns on Saturday to help with this trailer project. Former coworker and I erected the blast tent frame, (8X20) today over the back half of the trailer so I'll be able to blast inside and keep the mess at bay to clean up. Moderate to high winds forecasted so didn't stretch the cover over the frame, but I can do that by my lonesome. Grinding discs should show tomorrow and hope to get a bit more done before I start paying union wages again.....
That's All Folks!
Codger
Posted: 5 hours 17 minutes ago at 8:10am |
Well, I need to file a grievance or two with this deal. Union hall based heavy equipment operator says too cold, (18 degrees) to work and would be inhumane work conditions without an enclosed HVAC system on a skid steer. Don't know what I'm a gonna do and hopefully don't need to resort to "scab" labor to complete the task.
Received 100 new cutting discs yesterday so I'll get back after it later today. Temps are supposed to hit about 34 today and that's tolerable for this old man. Happy I elected to not erect the tent fabric as it was really windy from the west yesterday. Frame stayed put but I'd driven four of eight anchors into the ground to ensure that.
That's All Folks!
Posted: 4 hours 7 minutes ago at 9:20am |
34 aint bad... its the WIND thats the killer !!
have done many of those "me, myself and I" jobs..... Kind of hard to complain about the HELP then ! Edited by steve(ill) - 4 hours 5 minutes ago at 9:22am |
Codger
Posted: 3 hours 37 minutes ago at 9:50am |
Yesterday was terrible. Attended a funeral in Mt. Zion and the wind both up and down was very stiff. Wasn't that cold, but sure was cutting when crossing the crowded south 40 of the parking lot.
21 degrees now so a couple more hours and I'll get back at it.
That's All Folks!
Les Kerf
Posted: 47 minutes ago at 12:40pm |
Methinks she is a smart one!
