Driveway Overhang trimmed
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: Driveway Overhang trimmed
    Posted: 18 hours 51 minutes ago at 4:17pm
Will post pics later once download, otherwise rented a Local Lumber Yard Man Lift Trailer style, safety lock out switches on everything.  Enough for what did here, managed to raise canopy grown in with some spots under 10' to over 14'; the length of drive and pushed back the searching for sunlight growth beyond the mowed lines.  Forgot to count, but either eight, maybe nine repositions, required a Unpin/Repin at each reset.  Most stuff under 4" diameter just lots of it.  Took out a couple Elms and other garbage variety smallish trees.  Started at 8, finish at 2:30.  Yard has a Sunday Drop Off point so only Two Day rented.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 40 minutes ago at 7:28pm
i have never used one... brother in law rented one every 3-4 times with 40 ft boom to trim trees around the yard......... looked more like a forest... Kept the branches off the house , driveway, sunlight for yard..
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 8 minutes ago at 4:00am
All can say is better than ladder for function.  Very problematic machine and sensitive to over sensitive safety switch triggers.  Next round likely to try for a self propelled Man Lift as the JLG Line of machines where used those at the Nuke.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 34 minutes ago at 6:34am
This machine is a Plug In, charge Batteries, and Use.  No Engine for Hydraulics or Battery Charging.
