Driveway Maintance
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Topic: Driveway Maintance
    Posted: 28 Feb 2012 at 8:15pm
When grading/maintaining your driveway what do you use?  I have a 3pt blade and a 3pt box scraper but neither one are that great at removing washboards.  Some kind of a pull type grade would be better but also wondering about one of these.  Any input?
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 8:19pm
You  may laugh but from the mid60,s to about 2000 used our D 15 Series 2  and a snap coupler blade .
 Now we use a 3 pont blade .
 I have a half mile driveway .. the key is putting the road in right and   maintaining it
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 8:33pm
 For years we maintained our church parking lot,about 4 acres, with a AGCO box blade we purchased new for the job and by adjusting the top link shorter it would either easily cut washboards out or kind of ride on top and knock down the high spots if we lengthened it out a bit. Mostly loose 1/2" limestone.
For loose stone the drags that are similar to a H-D chain link fence work very well but you cant kep the crown in a single lane drive with one. Sounds like you might need a WC patrol or D grader?? Smile
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 8:41pm
i have used a GRADE-MASTER alot i love it!!! i worked for the MO. DEPT. OF TRANS. FOR 33 YRS. we had a 8ft. one you can do so much with it.if i had alot of gravel rd. to take care of i would have one.the only thing i would say is you need a 80+ hp tractor and pref. a 4wheel drive. Tom
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
AdamA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AdamA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 9:15pm
I use fwa 8030+rhino 1540 10ft blade....it'll cut darn near anything! sometimes more than I want!!
57'D-17,78'185,83'6080,76'7040,84'8030 FWA.02'Dodge cummins
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 9:49pm
I took 2-6' AC sc blades and had a welding shop make me a 10' blade. Used it on a WD45 for years. Now, I made a "T" out of 5"x7" tube. With AC brackets from a planter, the "T" mounts to the 3pt on my 7045PS. I made two plates out of 3/4 steel, drilled 4 holes and welded them to the back end of the "T". The back half of the sc blade bolts in these plates. So now my 7045 has a sc AC blade. The "T" is long enough so I can turn the blade 360* without hitting the tractor. I can tip the blade with the tractor 3pt arms or the adjusting wheel of the blade.
Edited by Unit3 - 28 Feb 2012 at 9:50pm
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 12:34am
Haven't found anything that works better than this bucket.....
I used to use a landscape rake to work up the gravel, but it is slow and no down pressure. I sometimes push a back blade in reverse to do finishing touches after the skidloader.
ALLIS EXPRESS!
This year:
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 5:20am
My neighbor has one of those back scraper's in the second picture.  It works great behind their 45 and is a well built unit
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 5:32am
Eldon that's a nice looking brush bucket you have there, who made it?
Don
RPSallispullinmd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RPSallispullinmd Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 5:43am
Neither one of the tools in picture will keep the crown in the lane you need to keep water from laying in a grave driveway.I have a small excavation business and use a 7ft box scrape but my compact 4710's have hydraulic cylinders in the 3pt so I can tilt side to side and in and out on the go.
Mike_426 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike_426 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 7:10am
I hang suitcase weights on my 8 ft blade turn it as far as you can to one side go both ways till you have a windrow , straiten the blade and fan it out pushing backwards ( much like a county truck would do ) that takes out the washboard for me
G, 200, 8050 mfd, D17, 195 chainsaw, c-wide front
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 8:15am
The farmer who lived across the street from me had a 500' long driveway,gravel and perfect! Every Sunday, after church, he'd go up and down about 10 times, pulling a big old beam and a section of heavy chain link fence.Seemed it took just long enough to get the tractor good and warmed up and have the misses make lunch !The old guy knew a few things ! Farmed that 50 acres for over 60 years.Best bean growing soil in southern Ontario.
Now the 'new' guy( NOT a farmer,rents the land to a jerk) complains all year then gets a load of gravel in ,just before winter, pushes 1/2 over to my side of the road when he snowplows....I give up telling how it should be done.....
irlbeck A-C'S View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote irlbeck A-C'S Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 10:37am
In our driveway we could just use a beach master with a beach cleanerSmile. Little different soil here. I have also witnessed some good results with the grade master. We normally use a 45 with  sc blade and the extensions on it. Does a great job. Once in a while we use a wd with a box blade  to move some sand that has washed down.  May be a slight overkill (but lots of fun) we'll let the the AC  M-100B do the work.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 11:11am
I use my Glenco field cultivator with a spike leveler behind on the shop drive. By spring it has chuck holes from the semi traffic. I dig it as deep as the deepest chuck hole when I see we will have several dry days in the forcast. I then float back blade several times and then drive the tractor or big truck up and down the drive to pack it back down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 11:33am
yes you can put crown in the road with the GRADE-MASTER once you get on to running it you can do alot with it' i have used one on 500+ mi. of road.like i said if i had alot of gravel road i would own one.
Reindeer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reindeer Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 11:46am
I have a '53 JD 40C crawler.  Angle the blade and back up leaving the windrow in the middle of the driveway.  Can adjust how much wiindrow  with the down pressure.  A round trip has it looking pretty good.  And you have wiped the crawler tracks away as you go.  Also quite effective for those wet heavy snow storms, but that's another story.Smile
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 11:55am
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 12:06pm
I drag an I beam from an old bridge and it does a good job.
Wink
I am a Russian Bot
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 12:33pm
Harley Power Rake!!
Gary (sw Wis.) View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary (sw Wis.) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 1:48pm
I use a D14 (or WD) with a box scraper. I added about 200 pound to the scraper. It gets to job done.
190XT - D17 - D14 - WD45 w/loader - WD - (2)B110 - 616H - 610 - B-208 - WD with 190 Mounted Corn Picker - All Crop 60
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 5:42pm
Our 400 ft. gravel drive from highway to farm shop was a never ending problem. After every hard rain we had to fill ditches that were eroded in it and then deal with potholes in the winter months. Finally after fighting it for 25 years,I talked my dad in to blacktopping it. It cost alot,but it was worth every dollar spent.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 5:45pm
But what about when it comes time to seal it or fix potholes, black top is nice but not trouble free either.
Bob-Maine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob-Maine Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 6:01pm
Our gravel drive is about 400 feet long. I used to grade it with a 7' three point scraper. a few years ago, I had a local contractor add about a foot of garvel and topped it with 4" of recycled asphalt (the stuff they mill off the highways). He graded it with a JD 450, rolled it and we have done nothing more. It is the cheapest and best alternative to hot mix asphalt. It can be regraded but I'm gonna add another 2 or 3 inches in a few years, grade that and roll it. Hot mix asphalt is nice, would have cost me more than $10,000 and in ten years I would have to do it again.
Bob@allisdowneast
I used to think I was indecisive, but now I'm not sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 6:05pm
Claus,you are right. Nothing is trouble free,but I can have it sealed with a truck (sprayed on) every two years for what I was spending on rock in a two year period. Gravel is just a high maintenance driveway most of the time and snow removal is almost impossible without removing some rock. I still have some gravel drives on the farm,it's just this one drive is the most used and is on slight incline. It cost too much for the blacktop,but it sure has made life a little easier.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 10:21pm
An old boss of mine took care of a 1/4 mile long drive to an old family cemetary in So. Illinois. He found best thing was a section of big I- beam about 8 feet long.By big I mean 8"X 24". He would hang weights on one side and would always keep the weighted side near the ditch. Worked well, would always pull some gravel towards middle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 7:48am
This is for sale over at yesterday's tractors, not bad, at least the blade is partially hydraulic.  This wouldn't be a bad option.
NDBirdman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NDBirdman Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 9:42pm
Has anyone tried this? http://www.drpower.com/power-grader.aspx My drive is bout 1/4 mile long, gravel and in need of leveling.  I don't have 3-point on my WD, so need something that will work with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 10:00pm
There was one for "barter" on craigslist out here forever....figured there was a reason it wasn't selling, either overpriced, worn out, or didn't work.
ALLIS EXPRESS!
This year:
