Drilling holes in concrete
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: Drilling holes in concrete
    Posted: 17 Nov 2025 at 2:43pm
Drilled 4 today. Brand new concrete bit. Went well for about an inch. Then it was tough. Does a hammer drill make much difference? I have more to do, Thanks
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 2:56pm
Big Difference with a hammer drill -bigger the unit the better and faster the drill works .
Trawler II View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trawler II Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 3:27pm
A rotary hammer drill and SDS bit will be a night and day difference. If you have a lot of holes to drill renting a rotary hammer drill and purchasing a bit is the way to go. SDS bits are a bit expensive compared to standard carbide, with a lot of holes to drill they are a bargain.
Edited by Trawler II - 17 Nov 2025 at 3:28pm
"Most people find it easier to believe a simple lie, than the complex truth"
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 4:39pm
If has Creek rock in the mix is like drilling granite.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 6:02pm
Thanks guys. Good info!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 6:08pm
Creek rock and rebar get in the way- take a punch when it stops and try to break the rock- we use Makita battery powered drills  and sds bits , they hold up well - and get used hard at work
Edited by DougG - 17 Nov 2025 at 6:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 7:20pm
What size holes are you drilling? Hammer drill and SDS Bits are the only way to go . Like others have said bigger is better. Rentals can pay for themselves quickly.
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 9:20pm
Years ago I had almost 60 holes to drill in 2 commercial bathrooms-tile and cement.  I started getting 12 holes drilled but wasted 4 bits-masonry in a hammer drill.  I said screw it and went straight to Hilti-bought a new SDS drill and their bits! They have a 2 carbide tip where most others are a one carbide tip.  Just used one bit on all the rest!
Greg Kroeker
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2025 at 6:36am
Plan B . Back out this morning for wedge anchors. One tapcon wouldn't hold. Feel sure I messed up the hole putting too much 'fat boy' on the drill
Drilling 1/4" holes. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2025 at 7:03am
Not too much fat boy on the drill but when trying to get through a piece of rock with a regular drill will cause the bit to wander. Hammer drill eliminates a lot of the wandering.
Gary (sw Wis.) View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary (sw Wis.) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2025 at 7:47am
Rotary hammer drill is the key. Not a hammer drill. And then let it do the work, don't push to hard you will be surprised.
190XT - D17 - D14 - WD45 w/loader - WD - (2)B110 - 616H - 610 - B-208 - WD with 190 Mounted Corn Picker - All Crop 60
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2025 at 7:51am
i have epoxied a few studs into concrete holes... set for 24 hours and then tighten the nuts... had good luck..
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2025 at 8:27am
Plan B didn't work
Guess I need an anchor for a 5/16 hole or maybe Steve's suggestion? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2025 at 3:39pm
Finally got the last fastener to hold. Thinned jbweld with acetone so I could get it in the oversized hole. Then put a 3" stud in. Thanks for the idea Steve. Before I try anymore concrete drilling I'll get the right drill. Thanks guys
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 22 hours 25 minutes ago at 11:32pm
The proper drill for the fastener is a must, and having a straight (not tapered) hole.
I frequently run down 3/4x7" wedge anchors using an SDS-MAX drill and 4-point drills.  Frequently performance will wane if one places pressure on the drill.  Don't try to force the bit, it won't fully clean and reset during hammer strikes.
Yes, rebar and river rock are impediments to drilling.  An annular big will certainly help, particularly if you have to go through rebar- it'll cut out the offending rebar easily.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 30 minutes ago at 4:27am
Thanks Dave!
