Drilling holes in concrete
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: Drilling holes in concrete
    Posted: 21 hours 42 minutes ago at 2:43pm
Drilled 4 today. Brand new concrete bit. Went well for about an inch. Then it was tough. Does a hammer drill make much difference? I have more to do, Thanks
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 21 hours 29 minutes ago at 2:56pm
Big Difference with a hammer drill -bigger the unit the better and faster the drill works .
Trawler II View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trawler II Quote  Post ReplyReply Direct Link To This Post Posted: 20 hours 58 minutes ago at 3:27pm
A rotary hammer drill and SDS bit will be a night and day difference. If you have a lot of holes to drill renting a rotary hammer drill and purchasing a bit is the way to go. SDS bits are a bit expensive compared to standard carbide, with a lot of holes to drill they are a bargain.
Edited by Trawler II - 20 hours 57 minutes ago at 3:28pm
"Most people find it easier to believe a simple lie, than the complex truth"
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 hours 46 minutes ago at 4:39pm
If has Creek rock in the mix is like drilling granite.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 18 hours 23 minutes ago at 6:02pm
Thanks guys. Good info!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 18 hours 17 minutes ago at 6:08pm
Creek rock and rebar get in the way- take a punch when it stops and try to break the rock- we use Makita battery powered drills  and sds bits , they hold up well - and get used hard at work
Edited by DougG - 18 hours 14 minutes ago at 6:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 5 minutes ago at 7:20pm
What size holes are you drilling? Hammer drill and SDS Bits are the only way to go . Like others have said bigger is better. Rentals can pay for themselves quickly.
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 5 minutes ago at 9:20pm
Years ago I had almost 60 holes to drill in 2 commercial bathrooms-tile and cement.  I started getting 12 holes drilled but wasted 4 bits-masonry in a hammer drill.  I said screw it and went straight to Hilti-bought a new SDS drill and their bits! They have a 2 carbide tip where most others are a one carbide tip.  Just used one bit on all the rest!
Greg Kroeker
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 49 minutes ago at 6:36am
Plan B . Back out this morning for wedge anchors. One tapcon wouldn't hold. Feel sure I messed up the hole putting too much 'fat boy' on the drill
Drilling 1/4" holes. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 22 minutes ago at 7:03am
Not too much fat boy on the drill but when trying to get through a piece of rock with a regular drill will cause the bit to wander. Hammer drill eliminates a lot of the wandering.
Gary (sw Wis.) View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary (sw Wis.) Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 38 minutes ago at 7:47am
Rotary hammer drill is the key. Not a hammer drill. And then let it do the work, don't push to hard you will be surprised.
190XT - D17 - D14 - WD45 w/loader - WD - (2)B110 - 616H - 610 - B-208 - WD with 190 Mounted Corn Picker - All Crop 60
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 34 minutes ago at 7:51am
i have epoxied a few studs into concrete holes... set for 24 hours and then tighten the nuts... had good luck..
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 58 minutes ago at 8:27am
Plan B didn't work
Guess I need an anchor for a 5/16 hole or maybe Steve's suggestion? Thanks
