Drilling holes in concrete |
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3088 |
Topic: Drilling holes in concretePosted: 9 hours 55 minutes ago at 2:43pm |
Drilled 4 today. Brand new concrete bit. Went well for about an inch. Then it was tough. Does a hammer drill make much difference? I have more to do, Thanks
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42062 |
Posted: 9 hours 42 minutes ago at 2:56pm |
Big Difference with a hammer drill -bigger the unit the better and faster the drill works .
Trawler II
Joined: 04 Jul 2017 Location: Missouri Points: 3544 |
Posted: 9 hours 11 minutes ago at 3:27pm |
A rotary hammer drill and SDS bit will be a night and day difference. If you have a lot of holes to drill renting a rotary hammer drill and purchasing a bit is the way to go. SDS bits are a bit expensive compared to standard carbide, with a lot of holes to drill they are a bargain.
Edited by Trawler II - 9 hours 10 minutes ago at 3:28pm |
"Most people find it easier to believe a simple lie, than the complex truth"
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34542 |
Posted: 7 hours 59 minutes ago at 4:39pm |
If has Creek rock in the mix is like drilling granite.
ACinSC
Posted: 6 hours 36 minutes ago at 6:02pm |
Thanks guys. Good info!
DougG
Posted: 6 hours 30 minutes ago at 6:08pm |
Creek rock and rebar get in the way- take a punch when it stops and try to break the rock- we use Makita battery powered drills and sds bits , they hold up well - and get used hard at work
Edited by DougG - 6 hours 27 minutes ago at 6:11pm |
Pat the Plumber CIL
Joined: 11 Sep 2009 Location: Springfield,Il Points: 4971 |
Posted: 5 hours 18 minutes ago at 7:20pm |
What size holes are you drilling? Hammer drill and SDS Bits are the only way to go . Like others have said bigger is better. Rentals can pay for themselves quickly.
1964 D-17 SIV 3 Pt.WF,1964 D-15 Ser II 3pt.WF ,1960 D-17 SI NF,1956 WD 45 WF. |
omahagreg
Joined: 11 Sep 2009 Location: Omaha, Nebraska Points: 2808 |
Posted: 3 hours 18 minutes ago at 9:20pm |
Years ago I had almost 60 holes to drill in 2 commercial bathrooms-tile and cement. I started getting 12 holes drilled but wasted 4 bits-masonry in a hammer drill. I said screw it and went straight to Hilti-bought a new SDS drill and their bits! They have a 2 carbide tip where most others are a one carbide tip. Just used one bit on all the rest!
Greg Kroeker
1950 WD with wide front and Freeman trip loader |
